ricky over here gets it, my man
Wow, nobody's called me Ricky since about 1973 when I was 10!
99 % no, once again, you push too far your demonstration attempt (which I don't really understand to speak frankly).No no, that's not what I said.
I didn't say just have whatever flaws. I referenced two highly common things that are present in 99% of consumer systems: a treble and bass boost, and a more narrow soundstage.
Even if you create your mix on a $5000 pair of pro speakers, if you aim to release for a huge audience, you have to check back on a narrow consumer system and see if the way you panned up your instruments works there too. If you've been too generous with spacing because you had a 60% bigger stage in your studio monitors, you'll have do adjust the stereo imaging so that it sounds as wide as you wanted on a smaller stage.
And the same is true for the EQ curve. If your studio monitors convince you that there's plenty of room to boost bass and treble, because it's ruler-flat around those regions, you'll make your audience's ears bleed and the lowend rumble. So of course you have to take into account the common boost that's present almost everywhere.
So it doesn't matter from which side I'm approaching this. I can either start at monitors and have to bump things up or I can start at consumers and reduce things. More realistically, because you'll be used to either system, you'll just naturally start placing the things in their proper ranges, because you simply know where that is.
How can you accidentally add "too little bass" because your consumer system boosted the bass and you thought there's enough of it? You'll still bring it up until it has a pleasant amount, in the fashion that you're used it on that system based of the thousands of songs you've heard. You'd immediately notice if your track feels weak in the low end. Because underpowering your bass, even with your boost, means that your track will still fall short in that region compared to everything else on that system.
The only scenario where this could happen is if someone buys a new pair of monitors and then starts right away mixing on it without ever listening to music on it. And in that case it doesn't matter if it's a studio or consumer monitor. The same person would boost bass and treble on the studio monitors as well beyond correct values, because they'd try to make up for the lack of it, without ever listening to music on that pair.
So it's not really convenient to sell this as studio monitors holding any advantage here.
What OP is doing is one of the main reasons of the audio's circle of confusion.
I know some consumer systems with blurred treble, other bass shy, others with a larger soundstage than reality, and of couse others with a kind of U curve, but certainly not 99%.
Congratulations - you are among the 0.01% of professionals who can do their job on a such low-cost equipment.I've been producing music for 10 years, released multiple bestseller soundsets for synths, used by big names in the industry and also worked for one of the biggest audio companies in the world as sound designer and composer. .... the quality of my work is appreciated by major industry players and their quality demands.
Now mind you, all these years I've been working with a pair of Superlux HD681 headphones and a Logitech Z533 speaker system.
Holkenborg did the soundtracks for many blockbuster movies like Justice League, Battle Angel Alita, 300 or Mad Max. Scheps mixed albums for Metallica, Michael Jackson and so on. And these two aren't the only ones, just the two I mentioned here because their work is part of the top 1% and should be enough to spark some interesting thoughts.Other 99.99% of professionals (among whom are names with much higher accolades than yours)
but because they know what they need to do the job right.
It does matter in various ways, I think you're oversimplifying the situation and ignoring a lot of psychoacoustics. The brain deals with direct and indirect sound differently, and we have to consider masking to decide (quantitatively) how much frequency response deviation is acceptable from a monitor used for mixing.It doesn't matter whether the coloration, artifacts, resonances and everything else that could possibly confuse you come from your room reflections or from the speakers, in both cases you're not having a signal representative of the actual, unaltered source, so that it will "translate instantly" as you claimed.
So we're done, case closed.
I think masking is the real reason why speakers with uneven FR can't *actually* be just as good as flat monitors, because at some point it becomes literally impossible to hear certain things in the mix if you have too much wiggle in your FR. This may not happen a lot in practice, but it's one aspect of hearing and sound reproduction you can't get around. If this were not so, MP3 wouldn't work.
And to @EngineerNate's point, it does matter if the flaws originate in your speakers or room, if only because the sound only gets worse once it leaves the speaker. Better to start with a clean signal, (arguably) especially if your room is bad.
A good large speaker able to play loud and low may degrade even more the resulting sound by exciting more room modes than a small speaker not playing loud and low (assuming this second one is not bad).
Having worked in consumer audio, selling stuff in that price range competing with logitech and other familiar names... lol sure maybe. Occasionally a good or at least pleasing design is very cost optimized. Often a cheap speaker is just a cheap speaker, with compromises made that didn't even need to be made.Today you can expect decent quality for around 150 credits, by major companies with experience in the audio field.
I think your content and working style has something to do with it. A single synth patch typically reveals its character with no problem on any speaker, in large part because the content tends to be entirely or mostly harmonic. So THD and even IMD won't tend to mask anything perceptibly, nor is there anything else happening you'd worry about being masked, it's just the one patch.Like I said, there's nothing ever in my tracks/mixes or patches I design for synthesizer that I wasn't able to hear on my speakers, that suddenly stands out on studio monitors.
I think your content and working style has something to do with it. A single synth patch typically reveals its character with no problem on any speaker, in large part because the content tends to be entirely or mostly harmonic. So THD and even IMD won't tend to mask anything perceptibly, nor is there anything else happening you'd worry about being masked.
If you were mixing orchestral recordings where you need to keep subtleties of room reverb and dozens of instruments in balance with none getting lost, I'd wager you'd view the situation a bit differently.
You don't like 100-watt subwoofers? Why?~100w sub
Nothing wrong with a 100w sub per se, but if it also happens to be a small one, it's probably not putting out much of anything below 45hz. I'm a 20hz or GTFO kind of guy.You don't like 100-watt subwoofers? Why?
Totally, my point was more around the fact that a single patch tends to be fully harmonic in nature, so however complex the sound, everything typically tracks the fundamental, and so if certain harmonics are masked it doesn't change the psychoacoustic perception of the sound very much. Two harmonically unrelated sounds where one gets masked would be A) more noticeable moving between flat and non-flat speakers, and B) more problematic. That might happen in like 1% of synth patches.And synthesizer patches can become very complex if you design them with multiple layers and many things going on in the same time.
I'm actually doing orchestral music, epic hybrid too, so the very complex soundtrackish stuff with dozens of tracks playing simulatenously, with different reverb group tracks for different depths (close, mid, far).
https://www.audiosciencereview.com/...-quasi-plain-wave-radiation.24396/post-925418 for example. ~200 litres eachNothing wrong with a 100w sub per se, but if it also happens to be a small one
I think that thinking is a sin.I think we all know
