Are stereo and 8 channel DACs too wimpy for you?
SHB
Well, bucker up there, Johnnie! DCS has you covered.
They have announced that they are going to make a 16 channel DAC using their latest and most manly technology. According to the press release, this DAC will increase the strength of your pimp hand to Snoop Dogg levels.
Meant only for manly men who do manly audio things.
Kal, baby, you’re harshing my mellow.
I mean, you’re bringing me down, man. You’re bringing us all down.:confused:
Out of curiosity, are these other 16 channel DACs of the pro or consumer variety?
Personally, never seen anything about them before.
Those are marketing matters. There are 16 channel DACs that qualify for both categories.
I am not throwing shade on dCS and I'd love to get my hands on one but, for the moment, I am more than happy with my Merging Hapi.
I've never used a multi-channel DAC - do they deploy DSPs for filtering so you can do miniDSP-type stuff, and if so, are there easy s/w interfaces to set them up? Is this their purpose?
Varies, of course, but a DAC is just a D/A converter. However, many pro DACs do have S/W interfaces that support plug-ins and apps, as well as expansion across multiple devices.
I know what a DAC is, I made a very early one at Uni. I'm also aware of plug-ins, APIs and apps that I use every day.
My question was really what is the application for 8 or 16 channels, if not for multi-band filtering (and that is a presumption of possible use-case on my part, given that DACs implement filters anyway)
I am using multi channel DACs because of Dsp Xover and room correction. That is my use case for years.
Multichannel monitoring/playback. For example, my basic playback system is 5.3 with possible future expansion to Atmos or additional subs.
It is as I assumed, i.e about filtering, but 16 channels seemed a lot before I thought surround systems.
Maybe multi-surround channels, each possibly with actively filtered tweeter/mid/bass and then subs too (for example) - is that where these devices are headed? Might need a x32 device!
Atmos or not can be an important distinguishing factor, depending on your use case.
Indeed. The use case in the original post is a setup that includes "eight total Perlisten S7i speakers reproducing surround channels, and eight Perlisten S4 speakers used for height channels."
Yes, speaker building, even if not 7.x, can use up lotsa channels.
Active DSP xovers, separate channel per driver, "virtual floorstanders" just in stereo can use up to a dozen.
Center channel might be another 2-3.
Then multiple mono subs for free placement to tackle room nodes.
Then surround, height...
no one needs to justify a personal preference.
My preference is no pricey AV gear, no proprietary codecs. But I do want to try upmixing, from vanilla stereo sources. So far I do enjoy Schiit SYN for some content, what do you recommend that might be better?
Pre-level only, if possible rather than integrated
