watchnerd
I used to work with a Revox PR99 Mk II... in 1985?
Yeah, mine are from that era, one from 1984, one from 1989.
Both bought within the last year, in my case.
Bottom line: for normal use, a good, fixed analog output range DAC, with digital volume control, will probably outperform a normal, not State of the Art, analog preamp.
Right, OK...
Now consider every D/A converter Amir tests, he loads its line outputs with a 200K ohm analyzer input. How is that remotely representative of typical power amplifier input impedances? Hint: it's not. Most power amplifier input impedances range between 10K and 50K, and with amplifiers incorporating input level pots, the impedance will be likely at the low end of those numbers.
D/A converters (line output) will have output impedances ranging from a few ohms (the good ones maybe) to many hundreds (or thousands) of ohms for the average ones. All of that combines to make the otherwise flat FR and low THD numbers less likely (if at all) to occur in a real system. Take the industry darling NC-500 (or equiv) with its unbuffered 1.8K ohm per input and tell me a typical D/A converter is going to perform well into such an impedance. And yet people are plugging sources into these modules without using an outboard buffer in some cases.
Good preamplifiers have output impedances below most of the headphone amplifiers tested on ASR. They can swing large voltages at very low impedances and happily drive long cables and multiple amplifiers with little or no modification of the ruler flat FR and low THD.
People obsess over headphone output impedances but rarely even consider the line output impedance of their D/A converter before eschewing a proper preamplifier and plugging in their power amps.
Actually, @restorer-john says, if I understood him correctly, that @amirm 's DAC measurements are not valid for that use case, since the AP has much higher input/load impedance than a typical amp or active speaker.If you're going to use a DAC with volume control, why not just go fully active speakers?
On the other hand, if a DAC does poorly with the easy load Amir uses, using a more difficult one isn't going to improve performance. I thought Amir used 100 kohm anyway.Actually, @restorer-john says, if I understood him correctly, that @amirm 's DAC measurements are not valid for that use case, since the AP has much higher input/load impedance than a typical amp or active speaker.
I don't know if @amirm uses some kind of load adaptation for his measurements.
My Genelec 1032A, as an example of pro active monitors, are given for an input impedance of 10kOhm.
The RME outputs seem, indeed, to be well protected against short.I am a little surprised the RME-ADI pro is 100ohms for unbalanced. Probably a series resistor to protect the output stage in case of a short
100kOhm for unbalanced and 200kOhm for balanced, for what I checked.all the dashboard indications are 200K ohms
But that's an indication of the internal load.
I don't think the AP measures any external load adaptation, like they describe here:
https://www.ap.com/technical-library/apx585586-input-impedance/
The APx555 may have difference internally-switchable input impedance, but I couldn't find any evidence of that.
Digital attenuation is less about loss and more about noise floor. A 16 bit stream can represent a dynamic range of 96 db, hence it has a noise floor of -96 db. If you would keep the stream at 16 bit and lower the amplitude of the signal, with each 1db of lowering you will get 1db closer to the noise floor, until at -96db your signal will be lost in the noise floor. Of course, you will hear a rise in noise way before that.
But digital volume control doesn't usually work like that. If you take a 16 bit file and stream it over a 24 bit stream, which has 120 db SNR, you can potentially lower the amplitude of the 16 bit audio by 24 db before any loss of SNR will take place. And it gets better as you improve your bit depth. At 32 bit you have potentially 192 db of SNR, so you can almost lower the 16 bit audio by its full 96 db SNR and just barely scratch the noise floor of the 32 bit stream.
You need also to consider two other factors. First is the practical SNR of your entire system, and of your own hearing. CDs were made with 16 bit because that’s way more than you realistically need to play any sort of music in any setting other than maybe an anechoic chamber. Since your base noise floor in whatever room you're are listening in is probably higher than 30 db, you don't really need even 96 db of SNR. And most systems will have less SNR, where amplifiers and mostly speakers are the limiting factor.
Dacs are usually the least limiting piece in the chain, and well-engineered dacs can easily have SNR of 100 db and more. And that’s the second factor to consider – you can only realistically use the bit depth whose SNR is lower than the SNR of your dac (called linearity sometimes). Say, if your dac has 110 SNR, you can't even use the full potential of 24 bit audio, let alone 32 bit. But that is not really a problem.
Think of it like this – say you have a base noise of 30 db SPL in your listening room (which is really low). If you set up your system to play 16 bit audio such that the quietest possible bit is at 30 db SPL, that would make the loudest possible bit (0dbFS) at 126 db SPL! Which is higher than the threshold of pain for humans, and is as loud as a jackhammer close by. You'll probably never listen to music at that volume, and I doubt most speakers can play at that volume without distorting terribly.
That means that most dacs has more than enough SNR to digitally control the volume without any perceptual noise floor. If a dac has that option built in, make sure it's converting the stream to 24 bits at least. 32 bits is the professional industry standard for audio editing, so anything beyond that is completely overkill. Nothing in the world has more than 192 db SNR anyway.
You have also clever solutions like the one in the RME ADI-2-DAC that uses digital volume control. In the default mode it has more than enough SNR to control the volume seamlessly, but if you are still concerned, you can optimize its noise floor by setting the base reference level to your liking using actual analog circuitry, to get the best SNR possible. It even has a mode in which it blends together digital and analog control to automatically achieve the lowest possible noise floor. But this is a massive overkill in most cases.
So to conclude, fear not from digital volume control. If the dac is decent and you resample your stream to 24 bit at least, it will be completely transparent.
mind blown. Thank you for this, I thoroughly enjoyed reading your post.
You could get an analog crossover like the Behringer CX3400 Super X Pro V2 or Behringer CX2310 Super X Pro V2. You feed its input with the RME or a preamp and the outputs go to the poweramps of satellites and subs.I got my infinite baffle subwoofer built for my HT setup and am now trying to integrate it with my 2 channel setup. What are my options to add this into a seperate stereo setup along with a nice quality DAC and power amps?
If I got something like the RME dac I could use the xlr outs to my speaker power amp. and the rca out to the sub amp? but what options to add a crossover for my sub? i was looking at the minidsp crossover and dsp solutions but would i have to add it in front of the dac or after? in which case how do i control the volume.
if its in front of the dac i can use the time delay to keep the sub phase equal to the speakers. based on location I need the phase of the sub to be slightly ahead of the speakers (sub is a short distance further than speakers). and i can use the crossover but I wont be able to use the volume control of the rme unless the crossover is after the dac.
I am not sure what my options are here unless I get a preamp or dac with a seperate sub output? any suggestions?
