Which is fine - but in most cases not audibly superior to digital volume control. Despite the claims of IFI.has an analogue volume knob
Cable impedance is the characteristic impedance which is only important > audible frequencies.Impedance of cables is expressed in ohms per meter? Or per feet?
In fact, I realized I don't need it (and agree, seen a little bit on the marketing side).Which is fine - but in most cases not audibly superior to digital volume control. Despite the claims of IFI.
Humm, according to the matemathical telegraph model, the inductance and capacitance per meter will begin to have importance in the line if the output impedancd of the attenuator is high. Is not my case, but in the case of the 5k passive device can become audible.Cable impedance is the characteristic impedance which is only important > audible frequencies.
Often wire resistance is given in ohm/km.
Capacitance and inductance per meter.
In the given expression capacitance and inductance per lenght can impact charscterisric impedance of the line.Cable impedance is the characteristic impedance which is only important > audible frequencies.
Either.Impedance of cables is expressed in ohms per meter? Or per feet?
XLRs are more immune and better. I thought you might be using RCAs, but clearly the link showed XLRs.I see, impedance is not dependent on lenght in usual distances, is a charachteristic value.
Why the lenght does matter in XLR balanced signals? Is the combination of the attenuator plus the cable lenght that can cause alterations?
If you are not turning the thing way way down, then it should be OK.I recently red about the common wire ground (L+R signal) resistance combined with R out and amp resistance can affect soundstage but I thought was only for headphones.
I have a quite particular output, Pentaconn balanced but this means that ground wire is shared by both channels. But my cables are 10 feet
I'm using XLR, WiiM RCA doesn't sound good in my home setup, I think either is a bad unit or I have issues with the electric installation because the differenece between both lines are too much high as expected.Either.
I would start with one device, and a single stereo amp and a single speaker.
If you can get that to behave how you want, then it should bode well for the second speaker being added in.
Probably makes as much sense to just use a beefier amp than biamping, but active XO have some advantages..
For analog audio and interlinks only the capacitance is of importance in combination with the output resistance of the source (or the output resistance of the attenuator which varies per setting).In the given expression capacitance and inductance per lenght can impact charscterisric impedance of the line.
Yes, this is what I learned from your contribution and other members help, and I wrote in my "acknolewdgement" message.A simple low-pass filter is formed
Thanks, this is very pracitc to know worst case and accptable case scenario.The main problem with passive volume controls is that the output resistance of the attenuator varies and so does the cut-off point.
It is 'worst' at -6dB attenuation (half the input voltage) and thus that is what is used to calculate the worst case.
Assuming the output resistance of the source being very low compared to that of the atttenuator you can set the R value for calculation of the -3dB frequency for the formed low-pass to 1/4 of the input resistance of the attenuator.
So a 10k potmeter has worst case 2.5k in resistance (at -6dB setting) and will be lower on either side of that volume setting meaning the -3dB frequency point will be higher.
For capacitance one should use the capacitance of the used cable length... so 10m with 220pF/m = 2200pF (2.2nF).
f(in Hz) =1/( 6.28 x R(in ohm) x C(in farad) ) when the found worst case frequency is above 50kHz you're safe.
That totally depends on where in the circuit this is done. Usually this is not done directly at the output of a source nor by changing the input resistance of a load so is independent of the cable parameters.Thanks, this is very pracitc to know worst case and accptable case scenario.
What about gain input? Switching -10 dB sensitivity reduction on the amp input has less inpact or equal than at the middle or source output?
I suppose by intuition that is better, because the attenuator is on lowest impedance or not needed and there's no more elements on the line after reduction.
I don't know where is the attenuartor implemented, in Genelec G Three the amp is on the speaker, but I imagine that this means nothing. Subjectively sounds better when activate the -10 dB input gain reduction on the speaker and the "fixed" switch on the DAC preamp side, than if I go full sesnitiviyThat totally depends on where in the circuit this is done. Usually this is not done directly at the output of a source nor by changing the input resistance of a load so is independent of the cable parameters.
Using an external attenuator (resistor divider) of course will but the output R to use in the formula is not 1/4 but 1/5 of the input resistance for a -10dB attenuator
Am I correct? What software should I use to see the harmonics?
I saw other mic calibration, frequently show some deviations on the mid-high region, but for instance I'm only correcting some modes and just the 2500 Hz dip that appears on 8030C Amir measurementsEven though I also use rather "affordable" Behringer ECM8000 measurement microphone (specially selected unit in 2008, ref. here #813 and here #819), recently I could fortunately cross-calibrate it and found it has still-nice/acceptable flat Fq response all the way through 15 Hz to 25 kHz, as shared here #831 on my project thread.
You (we) should be careful enough about Fq response of our individual measurement microphone(s) as I shared this diagram in my post there #831.
www.audiosciencereview.com
Yes, keep the length from passive volume output and the input of speaker or amp short. No problems.So do I understand this correctly that having 25’ before and 3’ after the XLR POT would be a non issue?
And the lower the volume is turned down the worse it performs.Yes, keep the length from passive volume output and the input of speaker or amp short. No problems.
