The measurements look plausible. Along the slab, GFR (gas flow resistivity) is usually less than in the perpendicular direction.
WLG45 also suitable for 0,5 m basstraps.
I am not. That is why I said without data we are in the dark. There is no place for guessing in acoustics.Are you sure that it does not affect <100hz when they are stacked?
I have to disagree. All acoustical anomalies are treatable. However, a simple subwoofer re-location can reduce the effects and is always cheaper and less obtrusive then a treatment.Bass Nulls and Peaks are next to impossible to eliminate. So we have to learn how to live with them and use them to our advantage.
i could move them so the open side faces the room and do a measure - do you think that makes a big difference?
it was ok for me but i was able to locate the sub which was... a bit annoying. i changed now the crossover to 80hz (was before 100 iirc) and will later watch stargate and see how it behaves. can i fix those dips with a second sub? i will EQ that and see what i can measure.
I am wondering what a good alternative to the arendal sub2 would be and how true the specs are for e.g. the KEF KC62. The website states it can play down to 11hz, and has only about 25x25x25cm.
Bare floors are trouble too. Try tossing some throw rugs on the floor use blankets if you don’t have carpet. Just to get a feel for how much can be gained by reducing the floor bounce. Hard reflective surfaces can also cause problems. Glass is another bad reflective surface. Pull the curtains closed. Throw pillows finally have a use. Throw them in the corners.they are mostly closed, yes. I built those when i had no idea and seems like i still have no idea as i was not aware (until now) that bass traps should be open on all sides facing the room
@sigbergaudio at 70 and 95hz
Is that the response of the room without the DIY bass-trap? If so be happy and enjoy the room.oh, thought it should only include - now again
can you tell me why this is with 45 and 105?
i can also upload the .mdat file if that helps
