are laptop USB inputs just (low-level) noisy? (for recording audio)
That seems at odds with multiple sources I read on the web, e.g. this,
The title of the homepage for that particular site is "Nutrition for Wireless Radiation Protection."
And it starts "The adverse health effects of wireless technologies and other types of EMF can be exacerbated both by deficiency of key nutrients (e.g., antioxidants) or toxicity (e.g., metal toxicity). The good news is that some foods and supplements can provide some protection against wireless health effects."
I'd maybe think twice about trusting anything it says :cool:
Even if a laptop power brick has a three-prong IEC input plug (and many do), that just means the power brick is grounded. It feeds DC to the laptop, usually something like 19V, with no earth ground. 19V is low enough that code does not require protective insulation, as would be the case with 120V (or higher). The power brick having or not having an earth ground means nothing.
The shell of a USB connector is DC-grounded to the chassis of the laptop, but that ground may not be at the same potential as the shell of the USB connection on the other end. If the device receiving power from the USB connection is also getting a different ground reference from some other source, you'll have a ground loop that will move current. But even without that, a floating DC ground connected at the ADC end can pick up common-mode noise from stray EMF in the environment. Digital signals filter that out completely if they remain bit-perfect. But I can see how that noise could find its way into the PCB ground of an ADC, causing noise leakage into the analog circuits.
I have a USB-powered Presonus interface, and also an independently powered Benchmark ADC1-USB. I have never tried to evaluate noise on these, but the Presonus loops back to no better than 100 dB SINAD when powered by a laptop. That is, of course, abundantly good for the things I'm using that sort of device to do (such as live recording and even some vintage equipment testing with REW). The ADC is not designed to a price point the way the Presonus was, of course, and even though it's much older it's also much better, by probably 10-15 dB. Which is largely inconsequential. But it does have much better controls, though the Presonus has phantom power and sufficient gain for condenser microphones, while the Benchmark is made for line-level inputs.
Rick "suspecting that Benchmark completely isolates the digital USB interface, even to the extent of reclocking it" Denney
I owe it to you guys, some of whom have gone well into the weeds on this, to give an update, maybe a finale.
After a bunch of byways and noise suppressors and cable adapters (but no, I did not manually ground the laptop or the USB shell), I realized that even my humble Boss GT-1B digital multi-effects pedal can serve as a USB audio interface, with negligable default latency, for overdubbing in Audacity. And again, USB-->laptop objectively was vastly noisier than the UBS-->desktop, when analysed under the most revealing (i.e. unrealistic) conditions.
I'm going to take the answer as simply 'yes' to my topic question, for my purposes. Your laptop(s) may vary. I'm just happy to have stumbled on an even simpler interface thanks to all this (but I'm using the desktop :) )
Two different laptops, similar issue.
