Sokel
- Joined
- Sep 8, 2021
- Messages
- 11,959
- Likes
- 13,360
To the last question, the ground plug probably earths the brick and stops there but that may not apply to all laptops.The input is RCA,. The device has RCA in/out , headphone 1/8" out, and USB out.
Either of its outs can be run into its in, of course. If that helps totest anything.
IIRC it is there with an input signal (my guitar), too. I will double check.
I still don't grok what 'shorting its RCA input' would mean unless it involves one of these
a-ha. I was going to say, how is any of that relevant if the desktop USB noise performance is 1000x better than any laptop USB?
You people...
what would 'run a thick wire from any laptop's shield connection to a solid ground around your house' look like? What is my laptop's 'shield connection'?
You and antcollinet converge here
I could use the laptop AC power source, which has a ground plug, instead of battery power, is that worth a try?
To test with the thick wire, just connect one end to a solid earth connection (like some bare metal under a radiator, or VERY carefully to the ground connection of a receptacle) and the other end to an unconnected USB shield (the shell) .
For testing it will be enough to see and compare if any of the junk is reduced.
