cedd
- Joined
- Apr 9, 2021
- Messages
- 15
- Likes
- 5
I'm not an audio engineer. From my current understanding a headphone with high impedance, say 300ohm, will draw less current than one with lower impedance, such as 37ohm. Is the end result that higher impedance headphones draw less amps and therefore drain less power?
And does this translate to how hot the gear will run? For instance, will the same amp run hotter with low impedance headphones than higher ones? And will the heat of the cable between amp and headphone also be influenced?
