DSJR
The C7 ES3 is about as warm and lush-toned as I personally feel a 'modern' speaker should be. Later Derek Hughes-era Spendors could be like that as well, although in the latter case, the cone surrounds harden after ten years or so and the sound suffers badly (brake fluid carefully applied to the surrounds and then wiped off, can restore them for a while. I loved the C7-XD when I heard them, as they now sound more neutral and like the larger 5XD, but judging by your comments above, you'd not prefer them at all. Stick with what you have!Thanks . I know there are lots of people who love the Croft / Harbeth combo and I generally fall into that bracket. C7 es 3.
My hearing isn't great ,(2 ops for surfers ear) and I'm increasingly finding it hard to listen too my set up as it tends to just overwhelm in the highs.
Maybe it's time to consider a change of Amps. Budget is minimal Pensioner and all that.
Also I seem to enjoy the music more when listening to the system from the adjacent kitchen! The sound in the lounge just gets too much and I have to turn it down to listen. Maybe the room is bouncing the high frequencies around and I need some room treatment.I would say it's moderately soft in nature at the moment, curtains, large rug etc.
I was a stick in the mud record guy, but now trying to live with a (bit perfect) digital source too, but honestly it's not being easy to love.Ive been trying to convince myself for a few years.I can appreciate cd playback in my system in many ways but it's still sounding hard and bright often. Could of course be down to bad recordings being shown up. I am a bit dazed
(old) and confused to be honest.
Is your room a lively-acoustic type with bare walls and floors? if so, a thick rug between the speakers and listening position may help. I'd also recommend 4mm gauge speaker wires even in shortish lengths (a minimal suggestion and inspired by my dealer days).
As for amps - ASR devotees can look away please
