Are Blue Jeans Cable LC-1 that good or is this guy right?
Yep, while a short run of LC-1 might be a poor choice for many phono cartridge to pre-amp combinations.
But if you need a long run, then LC-1 would be a great choice.
What most people don't realise is that the MM loading is the SUM of the C's.... if the phono stage has 200pf (which is very common) - then you need to add the capacitance of the cable ... a typical 1980's TT would be 100pf - making a total of 300pf.... which would work great for a Shure, or Ortofon MM, but typical AT MM's work best down at 100pf to 200pf... making them almost impossible to properly optimise on many setups!!!
Hence I personally stress to people that if they want to use MM's they need to have a phono stage with as little capacitance as possible and then use a low C cable (like LC-1) ... adding capacitance is very very easily done - you could use a more standard cable, or make some loading plugs with capacitors in them... - and the better phono stages often have switchable C load...(or the facility for loading plugs).
Depending on the stylus/body combination, some configurations work best with capacitance of 500pf (or more) - the majority though are around 200pf (and if you are fond of classic AT designs.... less, lots less!)
You can get the World's best RCA cable at 19.8 pF/ft which is in line with the LC-1. Mogami cable and Amphenol connectors used. This link is for 3 ft, but it is available as short as 6 inches.
The BJC LC-2 is lower capacitance at 11 pF/ft than the LC-1 or WBC.
Out of curiosity (and my ignorant on MM), is the use of a compensating capacitor/network relevant?
They are used in some measurement applications to compensate for cable capacitance. A classic example is oscilloscope probe compensation thou in that case most scopes have a ~ 1 kHz square wave generator built in for this.
Can be done... I experimented with it about 12 years back.... "Luckydog" on VinylEngine helped with it, and we called it "The Capacifier" at the time...
Those threads should still be there.
It does add another layer of complexity... which in this day and age, isn't really needed as we can achieve similar results with simpler loading and digital EQ instead... but if you want to stick to pure analogue, this is another technique that works.
I think that phono cartridge to pre-amp cables are a very different topic than LC-1 cables.
Any way we can start a new thread?
