Are Blue Jeans Cable LC-1 that good or is this guy right?
Yes, with a vinyl playback setup that can be an issue. I still shudder a bit at the marketing choice of "BJ" though.
I had a 1.5ft monoprice cable from my turntable to phono preamp. There would be a buzzing sound when I would place my fingers close to, but not contacting, the cable's connectors. The buzzing was even louder when I made contact with the cable. The connectors were all snug and not loose.
I ordered a 1.5ft Belden 1505F cable from Blue Jeans since it's a bit smaller and more flexible than LC-1, but has the same double braid shielding. The capacitance is negligible (9pF more) at this length. The buzzing completely went away now when I get close to or touch the cable.
I actually like this one:
I saw a couple of interviews with the designers and liked what I heard. Plus they got the ONE model not then million options like FraudioQuest :D
Yep, Kurt Denke at Blue Jeans Cable went to the Dark Side with that snake oil cable.
Agreed. I was a big supporter of BJC for years but they lost me when they made this move.
Yep, I thought that Kurt Denke @ Blue Jeans Cable would become the new noise, interference and cable expert. Because all the experts are way past retirement age or sadly no longer with us.
What's the difference, he chose an innerconnect vs a speaker cable from the overpriced snake-oil iconoclast line?
I guess if I wanted to test for an audible difference in cables, I'd look first to a low signal level, possibly susceptible to radiated interference, etc innerconnect rather than a speaker cable?
The LC-1 cables value is in the first 2 letters LC stands for low capacitance. For anyone who needs long runs from a turntable to an integrated amp’s mm phono stage the LC-1 measures at 12.2 pF/ft.
And if you seriously want to get low C, use a short run of LC-1... just make sure you have room for your phono pre just next to the TT...
The run from the phono stage to the preamp is normal line level, so not C or distance sensitive within reason.... but the run from Cartridge to phono stage, every bit counts!! (if you are working with MM's... with MC's it really doesn't matter, and in some cases you actually want high C !)
Welcome to ASR. Looks like your first post.
Thanks for the welcome! I've looked up various topics here off and on for the last year and a half since getting shared a link from a music related discord server I'm a part of. I finally decided to register a couple weeks ago.
Yep, while a short run of LC-1 might be a poor choice for many phono cartridge to pre-amp combinations.
But if you need a long run, then LC-1 would be a great choice.
