>> systems marketed as “active” in this configuration are nothing but false advertising and a rip-off for consumers
If you use "system" to mean an integrated installation of all the components, maybe?
But "Active Speakers" as a product category were around long before DSP went mainstream, actual vocabulary definitions may change with the trends but "false advertising and a rip-off for consumers" is overstating the case.
Same with "Active Crossovers", those include analog electronics.
"DSP based" crossovers is precise.
As is, for an overall system description "fully active is the way to go" as opposed to
"my 8-enclosure system is fully active except for the front main pair".
a combination of simple passive x-over with digital EQ could be a good solution when it comes to cost/performance ratio.
ABSO F'in LUTELY
With 12+ endpoint channels going all-DSP is just crazy pricey, one proprietary box costing more than all the other components put together.
I am going for "Modularised DSP", starting out testing a "DSP only where needed" approach.
If I have Main L/R comprised of a mix 2- 3-way speakers + midbass couplers + stereo trueSubs all co-located Those subs easily switched to mono if that turns out to test better, there are also other trueSubs already in mono thus freely placed, can be treated as a single sub-group in the DSP...
www.audiosciencereview.com
The processing that applies only to one enclosure (e.g. bass extension, driver EQ, limiter drivers protection) may be combined with multi-box crossover functions, or maybe leave the FR magnitude side to analog, just use DSP there if timing delays / phase alignment tuning is required.
Ad-hoc user EQ tone controls, loudness compensation tied to volume is 100% different from Room compensation
IMO neither having anything to do with an "Active Speaker". All my single-driver enclosures have no built-in electronics, but all are active.
> I would avoid any SW that requires updates to keep working.
Step further, all my software is "open" in the sense that any speaker enclosure can be swapped out completely, and the software does not, only minor configuration changes are needed - at the node that controls its filters, and tweaking the system-level DRC
