Apple Music with iPhone and External USB C DAC: Bit-Perfect or Altered Playback?
On macOS indeed, but on iOS and iPadOS you can see the DAC switching sampling rate following the content, at least with Apple Music but I guess this is true for any app using standard api.
The different behavior makes sense I guess: on the mobile devices a single app has exclusivity. On the desktop I understand some might be irritated by this fixed sampling rate but it allows to set up a chain with a convolver for room correction with a FIR, and that’s just a use case for us folks, for audio professionals there a plenty of other reasons probably. Personally I am not bothered by this and rely on a good implementation of the SRC.
Up-sampling requires a bit more horsepower... phones are designed to sip power so... ;-)
In terms of sound... depending on the music, source and the quality of your IEMS or Headphones... there's a point of diminishing returns.
With my Alpha, on my Macbook, I can hear a difference when I up-sample to the max of the device. (32/768k) However... its harder to hear a difference if I only up-sample to 32/384k versus the 32/768k. I'm sure others can.
Also I do hear a difference between my iPhone and macbook in terms of sound quality even without up-sampling. The Alpha seems to like having a bit more power which is why it has some issues w some phones and not others. (Some run it w an external battery/power source using an iBasso cable or similar specialty splitter cables. )
YMMV depending on your hearing and quality of your devices.
I apologize since this is getting off topic and beyond the OP's initial question.
Since the iPhone got rid of the 3.5mm headphone jack... you have to use a dongle which does have a dac built in. Amir did a review here and it did well...
You will definitely get better sound (even without up-sampling) using a dongle dac that has either 3.5mm or 4.4mm (balanced) out. You should be able to hear a difference between the 3.5mm and 4.4mm output. ( My Dita Project Ms allow me to switch connectors and I'm sticking w the 4.4mm )
While the Alpha isn't perfect... for $100 or so... best bang for your buck. Reviewers put the iBasso DC Elite above it in terms of sound quality, but its 4X the price.
Note: If you're going to put this in your pocket while you move about... the Apple Dongle is probably the best bet. The USB-C socket is a weak point on these DACs.
Not enough to worry a modern phone.
They can't. Nor can you if the up-sample is done correctly. In fact there is no audible benefit above 24/48. Or at least not that is audible to humans.
That is possible - but if you are, it will be due to lack of level matching or a power limit - rather than any inherent audio quality issue.
Yup its a power thing.
The Alpha Onix opened up w more power.
I think the big issue is the power difference since the dongle dac is getting its power from the source (pc or phone)
The sound stage seemed wider.
I also think that w the up sampling also helped w a bit more clarity.
I tested w both my Project Ms and I have a M&D MW65 using a 3.5mm connection. There was a greater difference using the Project Ms over the MW65s.
I suspect YMMV depending on the quality and sensitivity of your IEMs/Headphones.
But again, this is all subjective. So take it for what its worth... (Nothing)
Exactly - if you were to carry out the same comparison, but using controlled and blind listening tests those perceived differences would vanish.
PC + sabaj 2022 dac.
USB is a digital interface
Well, almost :) the USB-C connector standard also provides for a mode that allows analog stereo output and a microphone input. I have no idea how many devices implement this. Probably not many.
In case of the Apple dongle, it just has the tiny DAC and headphone amp built into the USB-C connector-end of the cable.
I had several oneplus phones that allowed that . Since I moved to pixels don't believe they do. Tbh I think I'd always choose a dac dongle with known performance anyway .
Reset... The pipeline in OS determines it's output and I don't have clue how it goes on iOS.
If exclusive mode means direct use of OEM or other USB Audio 2.0 driver in this case driver dependant and of course to DAC supported output. If it's seme-exact it's bit perfect but as much as you want it for storage, you don't want it to the analog transceiver's (aka drivers) and room if such. You want to do DSP processing on FP and glue it down (convert) to integer and you won't possible hear more than 19 bit (in mids-uper mids) or 20 KHz. Still it's useful to use higher output; for filters, convolutions and so on for various reasons and motivation (pushing the noise out of range, lower latency and so on).
Internal output to built in speakers is definitely heavily processed or it wouldn't go at all under 100 Hz (which it does).
Not exactly answer any of you hoped for but anyway best I can give you.
Well I can check the "learned something new" today box. Thanks!
forgive my ignorance.
I have a bedside headphone DAC / AMP
I previously used lightning to camera adaptor then usbA to amp USB-B in
I now have iPhone 16 with usbC out.
do I need an adaptor or will usbC out offer bit perfect stream to thee amp/dac connected iPhone usbC to amp/DAC usbB in ?
Qobuz is my hires player
I have no idea.
What I can offer is that "bit perfection" is a vastly over-rated concept, and offers no audible benefit except in the vanishingly unlikely event that any alterations to the bits are done incorrectly.
I don't worry about it. And I'll always advise anyone else not to lose sleep over it either.
I have no idea.
Ok. I will “rephrase”…
New Apple iPhone 16. USBC out…. Does it need a “dongle” or adaptor to supply full hires feed to outboard DAC ?
Again - no idea. For others who might know, they'll probably need you to state what you mean by "full hi res" - it might be capable of some sample rates but not others.
From my side I'll give you the same as last time. There is no audible benefit to "Hi-Res once you get past 24bit/48kHz
Yes, if you get a CX31993 dongle or something similar, it can output high-resolution audio. However, this is not the case with something like the Apple Dongle, which supports up to 24-bit/48kHz so it gets resampled. It's crazy how you're receiving these hostile non-answers on an 'audio science' forum. Nobody asked if there was an perceptible, audible benefit to it or not.
Also to answer OP's actual question I can't find a source to corroborate right now, but I believe iOS devices do automatically change the the bit rate providing bit-perfect audio as long as it is within the bounds supported by the DAC. Android used to resample everything to 48khz but apparently the audio subsystem has changed since Android 14 and it is better now.
Yes, if you get a CX31993 dongle or something similar, it can output high-resolution audio. However, this is not the case with something like the Apple Dongle, which supports up to 24-bit/48kHz so it gets resampled. It's crazy how you're receiving these hostile non-answers on an 'audio science' forum. Nobody asked if there was a perceptible, audible benefit to it or not.
I can sympathize with the original poster because of the ridiculous hoops I had to jump through to get my outboard DAC to display exactly what it was receiving from Apple Music. The jumble of wires and adapters between my iPad and the DAC to make it work was quite a sight. The bottom line in my case was that IF I was hearing any difference, it was so slight that I didn't even care about it. Still, it was comforting to prove to myself that for me, "there's no 'there' there" when it comes to HiRes formats for audio distribution. One less thing to be concerned with rather than addressing clearly audible issues like speaker/room interface.
It's similar to how some people get irritated at others for using Apple Music lossless or high-quality streaming services over lossy ones, or for choosing FLAC files instead of MP3 or AAC formats. While the difference might not be enormous, it still represents a quality improvement. Personally, I can hear some differences in AAC 256 kbps vs lossless, especially in the cymbals on tracks I know well. Why can't they accept that some people simply want the highest quality possible, whether they can perceive it or not?
MacOS has a „fixed“ (means no dynamic) sampling rate.
iOS will follow the contents sampling rate.
At least with Apple Music and an RME ADI-2 FS Pro DAC.
(To be clear: i guess iOS26 with „Automix“ enabled will lead to a fixed sampling rate as mixing tracks with different sampling rates wouldn‘t be possible then…But i didn‘t try that yet.)
my tests with iPhone 16 and iOS 18.5 suggest that:
Apple Music App (I mean the App when playing local lossless ALAC files, not the Apple Music service) is NOT bit-perfect. If it is a bug or intentional I don't know.
For testing I've used RME bit-perfect files and RME ADI-2 DAC FS connected to iPhone.
Sampling rate is auto changed but the good stops here.
16 bit files simply do not pass (why?)
24 bit files pass at 16 bit only
32 bit files rapidly switches between 16 to 24 bit, I mean that the display output flashes between the two values.
I have to check with iOS 26 if anything changed. Can e the particular test files used? I do know, I have no other ways to check.
I simply abandoned Music app for Onkyo Music Player
