Apple HomePod Review (Smart Speaker)
Did Atmos just work for you? We recently bought a pair for a guest room. However, Atmos isn’t lighting up on Music (iPhone13 Pro Max). I’m not sure if that’s because I’m using my phone, and the Home “owner” is my wife.
Yes, I did manually enable lossless under the home settings, Atmos was already ticked by default for me.
Are you playing via the pod itself, or via AirPlay? I don't think AirPlay supports Atmos.
What do you mean “by the pod itself?” I was playing Apple Music from my iPhone.
The Homepods can stream from Apple Music themselves, and if you do you can play Atmos. You control it either via voice, or via the 'Other devices' menu.
“Other devices menu”?
I found it - it’s in Control Center not Music. Kinda dumb IMO
It’s hard to find in that location. I believe it’s located there because it can be used to take control of streams from an Apple TV or even other iOS devices. In other words, it’s not exclusive to Apple Music.
This is a review and detailed measurements of the Apple HomePod smart speaker. It is on kind loan from a member and costs US $299. Apple recently discontinued them but I understand a few are still available.
There is no mistake that this is a product from Apple with impeccable look and feel:
The only way to communicate with the HomePod is using Airplay and Wifi. There are no inputs for anything else nor does it work with Bluetooth. I was expecting first class installation procedure but went through hell and back. You are supposed to tap your iphone on it to autoconfigure. I did and was pleased to see the pop up but it immediately demanded that I set up 2-step verification for my Apple account. What the heck? What does that have to do with installing a smart speaker???
It proceeded to send me to some other place on the phone where I was told once again my account was locked. Why or why? If you don't use the account for a while Apple just locks it on you? So then had to go through multiple steps of getting the account unlocked and then configure 2-step verification. By then some time had passed and I used the iPhone for my Bluetooth testing. Come back to the HomePod and tap the phone. Nothing happens. I tap it every way I can, no dice. Google and read everything there is to read about this and nothing comes up. The "home" app doesn't see it and won't manually configure it either. Nothing. Two days go by and I get the idea that maybe it is using NFC for autoconfig. Going to search for that and realize I had turned off Bluetooth. On a hunch I turn that on and bam! the pop up works and it autoconfigures. Amazing. This would be bad for any company but Apple? Not even put it in the FAQ that Bluetooth has to enabled?
Once there, the real challenge started which was measuring a speaker like this with Klippel NFS. Normal tests are run synchronous with Klippel generating the sweep and measuring with precision what comes back. That requires line or speaker level input, neither one of which we have. Fortunately Klippel has an way to solve this problem with two microphones (one for measurement and one for time). So I get a second mic, fish it through Klippel and start the first scan. Three hours later it is still going! It should have finished in 2.5 hours. I look and it has reconfigured itself to scan 5 times as long to the tune of 7 hours!
I start over after tweaking thing. Another 3 hours into 2:00am in the morning and the same result. More tweaking and more 3 hour cycles. So I ditch the HomePod and start with a Bluetooth speaker. That created its own problems of how to send the chirp data to it but got that working. So went back to HomePod, 3 more hours and same problem! :( :( :(
I realized that the issue would always appear near the end of the 2.5 hour scan. It would almost be done and then it would go crazy. I play the clip manually and realize first chirp was louder than the rest! The darn HomePod was getting too warm or something and reducing power/changing frequency response. This in turn would confuse Klippel software sending it into a tailspin.
I try to shorten the length of the scan and hit a new bug where no matter what I set it to, Klippel defaults to the same long scan. Frustrated, I blow the whole project, start over (at fair bit of pain due to having to reinitialize everything) and this time I am able to set a shorter scan. And this one worked! Results are below.
This is an unusual speaker in that it has an up firing woofer and then an array of seven tweeters all around the bass at the curvature of the unit. These interfere with each other and produce a massively complex sound field as frequencies go up. This in turn requires a ton of samples in NFS so that you are not limited by aliasing. Alas, due to HomePod overheating, I cannot run may samples. So what you see below is accurate to about 8 kHz. Above that, there is some error but on-axis response shows surprisingly good agreement so I think we are fine.
NOTE: I set the reference axis at the bottom of the speaker where the tweeters are. Setting it higher makes no sense since there is no driver there. In use, this speaker would be on a shelve with tweeters reflecting up from it. Same thing happened in the measurements in that the stand for Klippel which small for normal speakers was larger than the homepod. I thought this better represented how it is used so I went with it.
Apple HomePod Measurements
Alright, let's start with our standard frequency response graphs and "spin" data:
We instantly see the heavy bass emphasis and somewhat uneven response. Due to high frequency drivers firing in each way, on-axis actually shows less energy that total sound power which is the opposite of how normal speakers behave. Your actual "on-axis" may be more like Sound Power depending on whether the rear firing drivers reflect back into the front. The omni directional aspect of the drivers naturally generates very symmetrical off-axis response and indeed, off-axis is the same as on-axis:
Predicted in-room response doesn't quite apply to this speaker but I suspect it is speaking the truth when it says there is too much bass here:
Horizontal beam width tells us what we already know from its physical construction and measurements above:
The directivity plot is so unusual because of it:
Vertically we have a puzzle that takes some work to decipher due to reflections from measurement stand looking down at the speaker, and blockage looking up:
I don't have other measurements for you as I lost my on-axis in-room distortion graph when I restarted the project. Can generate them again if there is time and interest.
Apple HomePod Listening Tests
I started with my usual female vocals and sound there was pretty good. Even at max volume there is no clipping or any sign of overt distortion. Oh, for placement I put the speaker on my equipment stand where I listen to near-field speakers. Listening distance was about 1 meter/3.3 feet. Gradually I started to get annoyed by the level of bass. It was always present no matter what I was playing. So I reached into my equalization tool and cleaned up the response some:
The result was much, much cleaner sound Gone was that constant boominess. The EQ is likely not correct in that room modes interfere so more exactly work needs to be done in situ. Taking away the extra bass seemed to accentuate the highs a bit. Measurements didn't show this so don't know why this was the case.
The omni aspects of the sound was nice as I moved left and right a ton and tonality remained the same which was very good.
When it was said that done, it was a mono speaker that could play somewhat loud without distortion. Eh. Nothing exciting. A pair of active speakers would sound so much better. So in the larger context for our kind or use, this is a bust.
The Homepod obviously has benefited from excellence in design. I wish they had used their DSP though to provide different target responses. I get that bass sells but give the rest of us some tuning. Oh, I tired "SoundCheck" but it did nothing that I could detect in listening tests.
At the end, there was nothing exciting for me here. I could not listen to the Homepod without EQ. With EQ it was fine but I wasn't sure what I was getting at the end.
Overall I can't recommend the Apple HomePod. Go ahead and complain that I am a Microsoft guy and don't like Apple product. I will point you right back at the above measurements. :)
How did you EQ them?
Then I remembered that Apple does Atmos now too and so I decided to try the OST of Dune in Atmos on these things and well... Wow! This sounds great! I compared to the rig in my signature and well... I think that at least this OST sounds better on the 'pods, which are still rocking the reduced bass-option.
It's getting late here so I this was only really a first impression, I'll have to wait until tomorrow to try out more Atmos material on them. But dang, I'm looking forward to it.
I'm flabbergasted.
This comment has me genuinely intrigued! Just out of interest, how did more testing go? And is the signature system mentioned your current one with KH 310s + subs and dsp? I have a weird thing for omni / multi room and have been thinking of getting a pair of HomePods or Teenage Engineering OD11 to scratch that itch.
It went as expected I suppose, the Homepods do work very well with Atmos if the album is meant to be airy/spacious - a few other OSTs are avaiable in Atmos on Apple Music and they mostly sounded really good. Otherwise, a lot of music sounds rather bad, or at least not very engaging, on them. Considering the price difference of two Homepods vs. the setup in my signature I cannot really fault them, I still think it's really impressive how they can sound so good given the right circumstances.
If nothing else, the experience has me interested in MCH music now. I don't feel like coughing up that kind of money yet though, especially since only so much of the music I listen to is available in MCH. Can't really figure out where'd place the speakers and run the required cables in this room either.
Reactions: mmi
Noting that there is a setting for “reduced bass” accessible via the HomePod settings in the Home app.
I find the HomePod is great for low volume evening listening where the bass is very solid. If you want to play loud, the reduced bass setting works better.
I think for a smart home speaker it measured quite good, esp since it goes all the way down to around 30hz, thats pretty incredible imo. Its expensive and it does clearly show that it was designed w/ intent to hit certain acoustic objectives, imo thats all that really matters.
I own one since the product launch. I first used it in a small room and indeed sounded bass heavy. I moved to a new place and bought a second one, used in a fairly large room and a stereo pair is much better. At low volume the bass is still present but at higher volume (and not super loud either - there is definitely a limiter to avoid damage but this kicks in later) I think the balance is quite good.
It's interesting how it detects back wall and change the directivity. There is also a kind of variable loudness, so reducing the source volume while increasing the HomePod volume to maintain a given SPL changes the response - from iOS there is no easy way to do that though, at least with Apple Music.
Apple should definitely add a possibility to EQ them. Take inspiration from the B&O Beosonic (probably patented) for a similarly easy way to dial in the "tilt" and "smile".
iu
I've got two homepods, finally tried out a stereo pair with some dolby atmos tracks in Infuse and music. Pretty impressive and they do seem to widen the sound stage to the side. On playing back channel ID white noise there were no effects to the side or behind me. It's apple so they won't offer any customisation options but Dolby Virtual Speaker has been around for a long time and can easily steer objects behind you from a stereo set via cross talk cancellation and HRTF. Theortically the Homepod's could know where you're sitting by you saying "Hey Siri" and then adjust their magic to direct cross talk correctly.
I wish Apple would go ahead and just do multiple homepods for a surround system that they have a 2019 patent from (https://www.flatpanelshd.com/news.php?subaction=showfull&id=1548065400).
I used to carry the homepod with me on trips cause it was an excellent sound bar for airbnb's. But since Spatial Audio is now supported for two listeners from the Apple TV our Air Pod Pro's now constitute and entire 7.1.4 system that weigh 50g. That experience blows away any homepod and is, for my purposes, the same as lugging around my entire AV kit with me. Still blows my mind that I get accoustically the same experience without lugging around 100kg of gear and wires.
I'm quite curious, given the small size, how are they able to reach the deep bass response. From what I've seen it seems that they actively monitor the woofer state and drive it to the excursion limit? The design seems sealed? I wonder if this method of driving woofer will show up more in other actives.
Side note, seems like Apple uses Genelec
I do not get any effects from the rear using AirPod pros. From along the sides of the sound field, yes, and diffuse overhead effects. But SFX behind the listener? Not really.
I am not exactly sure how it works, but the Homepod 1 vibrates a tonne. Placing it on a surface like a side table increases the bass output a tonne, by what I assume is vibrations of the surface that the speakers stand on. I imagine that this output creates a lot of distortion though.
On top of that, yes, the bass speaker is a long throw speaker controlled via DSP. It goes impressively low, but not loud at the same time.
It would be interesting to see the Homepod 2 on the Klippel. Other than the too bassy sound profile, I am still very impressed with the Homepod 1. Considering that the Homepod 2 seem to be lighter on the bass compared to the previous generation in general, I wonder if they simply would sound a lot better due to this. My main gripe with the original Homepod was that they sounded messy with a lot of music genres that I listen to (rock, metal, electronic noise etc.). But I am fairly certain that this was an EQ issue rather than a speaker quality issue if that makes sense, the HP1 sounded excellent with a lot of materials and it was truly annoying that the lack of sensible EQ possiblities ruined what was othewise an impressively capable speaker.
I am still miffed that I couldn't set up an Atmos system using the original Homepod at home. Them being wireless (other than the AC chord naturally) would make installation so much easier than regular speakers, but no, you can't go beyond a stereo pair even to this day. Could've been so good for a cheap home cinema, and it would've really elevated Apples Atmos offering. The Dune (2021) OST soundtrack sounded better on the stereo pair of Homepods I had set up at home than any other speakers I've had in my home, including my current setup. Truly breathtaking.
