Extreme_Boky
- Joined
- Jun 9, 2020
- Messages
- 134
- Likes
- 87
The evidence is right there in front of my eyes. The combined heat dissipation is too much for that design. Even with the minimal heat dissipation mentioned above, if the amp is placed in a rack (quite possible... after all, it is a class D amp that supposedly runs cold, so an average user may be tempted to place it on the middle shelf, for example), it will overheat. The capacitor electrolyte will dry - especially in that harsh high-frequency switching environment, and hot spots will develop.
Apollon can take my constructive feedback on board or choose to ignore it. The start would be to actually measure the power usage from the mains socket, and take the temperature measurements under the conditions I stated earlier, with the top lid closed. I trust that a sensible decision will be made to insert a current hungry OPAmp in DIL8s, to mimic the actual use case.
This has nothing to do with you. You have no idea what my background is, so you should be quiet instead of polluting the thread trying to prove you know stuff/have experience in electronics design.
With external temperature approaching 50degC, what do you think the internal temp would be??? Do you think that the side vent will help circulate the air and provide any sort of conventional cooling inside that thing???
