This is an engineering, manufacturing and design issue. It has little to do with "science." Let's reserve using big word arguments for others.
If you don't properly ground your amps, are you going to demand that I show you some electrocuted before you properly ground it?
So no, it is not my job or John's to tell you what is obvious and understood in design circles. Cheaper caps can result in lower reliability. You want to prove they don't, then be my guest. But don't run off with negative logic there.
...and engineering, manufacturing and design are not based on scientific work and the scientific process ???????????
Including the comments and conclusions drawn and published here?
Sorry Amir but you its you thats running the reverse logic.
Your comments here are actually confirming the position and point I have been making all along. Yes this is absolutely an engineering, manufacturing and design issue which is precisely why you cant generalise in the way you are.
Lets look at your ML DAC. How much did it cost again?
Why did this premium brand cap fail?
I would say that it was most likely to be due to the fact that is sat right next to two power resistors and a power transistor / voltage regulator. These components by definition will be hot. Maybe very hot. Elevated temperature = shorter life.
So are you now going to argue that this was the caps fault? That it is a shit cap? Or are you going to accept its just bad design choices?
Now if this had been a "lower" brand cap, its clear from this thread and your comments above that your reaction would have been to blame the cap. Thats obviously wrong.
As I keep saying, you cant generalise.
