- Joined
- Feb 13, 2018
- Messages
- 594
- Likes
- 779
@Apollon Audio, what will be the gain of the nc2k amp?
How low can it be set to? How many dBu can the input buffer handle without clipping?The gain in our PNC2K is 34dB by default (...) We can also make the gain custom if desired
to put things in perspective:How low can it be set to? How many dBu can the input buffer handle without clipping?
I was talking about this one. The zoomed in picture is not the same unit. My major complaint would be taken care of by moving the XLR inputs to the right of their respective outputs. Nobody looks behind the amp anyways so the external grouping is unimportant.
also regarding above chassis, although you can basically multiply the size of all those holes in the bottom by 4-10 x, and then use that to determine the wavelengths of the frequencies they will allow to pass through nearly unhindred. Certainly not an issue for the fundamental modulation frequenciy but not necessarily the harmonics. What does the FCC say about these units?
What does an FCC-compliant chassis using an NC-XXX module look like??
gain of the bare nc2k module (buffer-less) is 20dB/x10, implying a 23.2dBu/11.3Vrms sensitivity for a 8 ohms load (and a bit less at 4 ohms).
A 34dB/x50 gain (ie 14dB gain in the buffer) implies a 9.2dBu/2.3Vrms sensitivty @ 8ohms.
So to rephrase my question: can the buffer be made unity gain, and can it in that case handle 23dBu without any sign of clipping/distortion?
If not, what is the lowest possible/sensible gain setting?
Slovenian potica consists of a rolled pastry made of leavened paper-thin dough filled with any of a great variety of fillings, but most often with walnut filling. The most characteristic Slovenian poticas are made with ground walnut, tarragon, quark, hazelnut, pumpkin seed or poppy seed, salted ones even with cracklings or bacon, and other fillings...
Tell me what. I must miss sugar. They call me to cook a fideuá. https://www.google.com/search?q=fideua
