Apollon 1ET6525SA ST Purifi-based class D amplifier an Q Acoustics 3050i?
josef119
Hello everyone,
I was very impressed by the test of the Apollon 1ET6525SA ST Purifi-based class D amplifier (https://www.audiosciencereview.com/forum/index.php?threads/apollon-1et6525sa-st-amplifier-review. 68779/) – not only by the measurement results (thank you very much for those!), but also by the apparent solidity of the construction. In the future, I would like to replace my Wiim Amp Pro (which I really like) with a higher-quality amplifier. Does it make sense to use such a powerful amplifier as the Apollon in a room measuring around 30 square metres with Q Acoustics 3050i speakers? Or would it be completely oversized for the speakers, for which the manufacturer recommends 25–100 watts? Could the amplifier even damage the speakers? And finally, the question of how to find the right gain settings, which I have not yet been able to set on any of my devices.
Many thanks in advance for your answers to a hi-fi fan who is not particularly tech-savvy, and best regards!
Josef
Translated with DeepL.com (free version)
My best advice is:
Buy a cheap multimeter, measure your WiiM's output voltage with volume adjusted to your preference, and that's all you need to compute how much output power and gain your new Amp would need to have.
That being said, you'd be significantly better off investing in a new pair of floorstanders, a subwoofer or two, a measurement microphone, or some room treatment instead.
If you want a new Amp hoping it will improve something, without knowing what that is or having solid grounds that it'll do what you want it to, then you're most likely wasting your money and the new Amp will sound exactly the same as the old one (excluding expectation bias).
If you keep playing and pushing even if the speaker is already crying out for mercy so to say, then yes.
It is hard to damage your speaker because your ears will hurt before that. The likely scenario is that you for some reason leave the volume at max, start playing some song then turn on your amp. But even then I would be worry about your ears more than the drivers.
Upgrade the amp because you 1. Have a bad amp that is high distortion and/or clearly underpowered (not this case), 2. Have the money to spend and you already optimized other things. I don't need a new amp but I usually think about buying a purifi because, well, it is nice.
Things you can try.
- room correction
- room treatment
- add a sub, or two
- speaker placement (move left, right, away from wall, toe in, toe out)
Agreed with the above, and probably the speakers themselves would be better upgrade than the amp driving them.
...I would buy the Buckeye 6525 amp...
I've been looking into this as well and have some questions. The max line output setting for the WiiM Ultra is 2vrms. From what I'm reading, the Purifi 1ET6525SA amps (at least the ones on Buckeye website) seem to require 2.3vrms on their highest gain setting to reach full power. This means that if the Ultra is connected directly to the Purifi 1ET6525SA the output would be limited to158 watts rms into 8 ohms. If you increase the input to 2.3vrms you get 209 watts out, but that would require a preamp.
Is this correct?
Is this correct?
That is correct, however, the difference would only be about 1.2dB
You can try this right now with for example Equalizer APO and I think you'll find that a 1.2dB difference is basically inaudible.
Plus that basically inaudible difference would only be there if you make use of the Amp's last ~8% of loudness anyway.
If you're not in need of completely maxing out the Amp, then buying an additional Preamp would be pointless.
Reactions: rjp
Thanks for confirming.
Looks like I can get about 239 watts rms from the NCX 500 with same input by same math. Assuming I get the standard hyper gain stage not the lower gain buckeye option. 26dB/2.5vrms
