The cases are gorgeous but expensiveAs has been discussed before: No, not really, comparing apples with apples.
Give an example in how the product is more expensive than a comparable one from another make.The cases are gorgeous but expensive
I’ve noticed that you’ve raised concerns about the pricing of our premium and lux enclosures several times throughout this thread, so I thought it would be appropriate for me to step in and provide some clarification.The cases are gorgeous but expensive
9/10 I'm deducting a point for the car analogy.I’ve noticed that you’ve raised concerns about the pricing of our premium and lux enclosures several times throughout this thread, so I thought it would be appropriate for me to step in and provide some clarification.
You’re missing a key point: enclosure cost is not linear, it scales dramatically with material thickness, machining complexity, and production time.
A 10-20 mm aluminum enclosure is not even remotely comparable to a basic 2-3 mm one:
A 2-3 mm enclosure is typically bent sheet metal, often stamped in large batches. A 10-20 mm enclosure is closer to a machined block product, completely different manufacturing class.
- Material cost alone is several times higher (10-20 mm billet vs thin sheet)
- Machining time increases significantly (CNC time is one of the biggest cost drivers)
- Tool wear is much higher when cutting thick aluminum
- Weight increases → higher shipping and handling costs
- Finishing (anodizing thick parts evenly, polishing, tolerances) is more demanding
- Often these are low-volume, precision builds, not mass-produced stamped cases
So saying “it’s just a case” is like comparing plastic trim to a solid milled chassis.
And honestly, this is the same logic as cars:
Some people buy a VW, some buy a Mercedes or BMW. Both will get you from point A to B, some even share the same engines, but questioning why the Mercedes costs more misses the entire point of what you’re paying for: materials, engineering, refinement, and build quality.
If you don’t value those things, that’s perfectly fine, but then you’re simply not the target customer for that product category.
Fair point on the analogy, it was just a simplified way to illustrate value perception.9/10 I'm deducting a point for the car analogy.
Your statement is only partially correct, but it misses a key point about how real-world thermal systems behave.Mass alone affects only the time it takes to reach a specific temperature, it doesn't actually increase cooling capacity. Shape has way more effect.
The car analogy doesn’t translate to thermal systems the way you think it does.Bad car analogy time: same power and aerodynamics assumed, a heavier car reaches the same top speed as a lighter one, it just takes way longer. The lighter one will be more usable and fun both, because it actually reaches those high speeds under practical conditions while the heavy one simply takes too long.
(This is arsebackwards relative to heatsink mass effects of course, a beloved tradition in bad car analogies)
Oh come on, I appreciate your detailed explanations but you didn't seriously expect a short, deliberately cheeky comment to be accurate?The car analogy doesn’t translate to thermal systems the way you think it does.
You are treating the enclosure as “just added mass”, which would only affect how long it takes to heat up. That would be true if the material had low thermal conductivity or if the heat path to ambient was limited. That is not the case with a thick aluminum chassis.
Aluminum is highly conductive, so the enclosure does not behave like a lump of mass. It behaves like a heat spreader. Heat is rapidly distributed across the entire chassis, which means you are not dealing with a small hot source anymore, but with a large effective radiating surface.
That directly changes steady-state behavior, not just warm-up time.
Ask yourself this. If you take the same heat source and couple it to a tiny heatsink versus coupling it to a 15 kg aluminum block with large external surface area, will both stabilize at the same temperature. Obviously not. The equilibrium temperature is defined by how effectively heat is transferred to ambient, and that depends on usable surface area and temperature distribution, not just shape in isolation.
Your analogy assumes identical cooling conditions, which is the core flaw. In reality, the thicker enclosure increases the effective area that actually participates in convection and radiation because thermal spreading is far more efficient. A thin case cannot utilize its full surface because heat remains localized. A thick aluminum chassis can.
So no, it is not “same top speed reached later”. It is a different equilibrium point because the heat rejection mechanism itself is improved.
What you are describing would only be true if both enclosures had identical thermal conductivity and identical effective heat spreading, which they do not.
That is why a properly designed thick aluminum enclosure is not just delaying heat buildup, it is acting as a fully integrated passive heatsink and lowering operating temperatures in steady state.
Here's everything about it, including the math, etc:Wondering if there is a mechanical and electronic engineer who can confirm what was said?
www.designworldonline.com
Done my share of thermal analyses when I was working, but not enough to tell just by looking at the design. Qualitative hand waving is easy but gives no details to the story. Let's put some actual numbers in and run some simple FEA's to see what are the differences between beefy and skinny heat sinks.Wondering if there is a mechanical and electronic engineer who can confirm what was said?
Nice effort putting numbers behind it, always good to see actual modelling instead of just opinions.Done my share of thermal analyses when I was working, but not enough to tell just by looking at the design. Qualitative hand waving is easy but gives no details to the story. Let's put some actual numbers in and run some simple FEA's to see what are the differences between beefy and skinny heat sinks.
I ran my model using the TI TPA 3255 instead of the Purifi because the parameters are easier to find. The heat sink is modeled is the one used in the TI eval kit. I did the FEA in 2D since it is easier and runs faster, and I am not after high accuracy. I modeled the heat sink (cross-section) as-is and one with fins and the base half thickness. For the skinny case, the fins are 1 mm thick and the base in about 3 mm thick. The thermal contact area between the TPA chip thermal pad and the heat sink is 4 mm wide.
Here are the meshes.
The TPA heat dissipation (heat load = 22 W) is for 1/8 rated power for 4 Ω load with BTL configuration. The 1/8 rated power figure is used as it represents the typical crest factor of dynamic music type signals. I used a convection heat transfer coefficient of 7.7 W/m²·K, based on these class notes. This number is reasonably suitable for natural convection in a well ventilated area (i.e. not enclosed). The physics of convection heat transfer is highly complex and analyses results aren't going to be highly accurate. There is no need for highly precise parameters.
The top graph is for the beefier heat sink, and the one below is the skinnier. The steady temperatures are very close to each other, as expected. The faster temperature rise of the skinnier heat skin is due to it lower thermal mass, also as expected. The solid black lines are for a lumped mass of the same mass as the heat sink, and without any heat transfer to the ambient. It is for a quick check to see if the FEA results are reasonable (the initial slopes should match).
Here are the detailed temperature distribution plots for the first 5 minutes (300 seconds). At steady state, the max-min temperature delta for the skinny heat sink is about 6.5 °C whereas for the beefy one it is 3.8 °C. Not a significant enough difference, and no hot spot problem with this skinny heat sink (for this application).
