@Jukka, I'm curious ... where would you place the knee for the 9040BA module power curve below for 8 ohms (
black line)? From your reasoning, perhaps at 200W, where the distortion starts to rise? Or 300W or 400W, where it definitely shoots up to the skies? BTW, Purifi rates this module at 375W into 8R at 0.1% or -60dB THD+N. As I explained earlier, this is industry standard, and the FCC has not changed it, as far as I can tell. In fact, a manufacturer is free to rate their amp at
any distortion level. Purifi would also be correct if they rated their 9040BA module at 200W with -130dB THD+N or 300W with -125dB THD+N. But that would be 'wasteful' and unrepresentative of the true performance of the module.
Also, a slight correction to a statement you made: "
Harmonic distortion does not, however, make the fundamental (original input signal) any louder (except for H1, if there is such a thing)."
When you look at a 100W (~28.3Vrms into 8 ohms) waveform on the scope at -130dB THD+N, it will be clean. Increasing the power to 200W (40Vrms) or 300W(~50Vrms) at higher distortion levels, the primary waveform amplitude (H1 in this case) will linearly increase and will continue to do so at 200W or 300W. By the time it reaches 375W in this case, the input voltage amplitude
will not cause a proportional change in the voltage output, but H1 will continue to increase along with higher harmonic products, just not at the rate as the input (and you'll still see a clean looking voltage waveform on the scope) ... until it just stops increasing when its peak voltage waveform is equal to the module rail voltage (typically +/- 46VDC for this module). Then, a rounded sine wave results, as I explained in my earlier post.
Good and interesting back-and-forth,
@Jukka
