Apollon 1ET6525SA ST Amplifier Review
Rate this amplifier:
    Votes: 0 0.0%
    Votes: 2 0.7%
    Votes: 34 11.8%
    Votes: 252 87.5%
This is a review and detailed measurements of the Apollon 1ET6525SA ST Purifi based class D stereo power amplifier. It was kindly loaned to me by a member and costs 1,190.00€ (USD $1,348).
Apollon designs are unique a step up from some of its competitors. Even the power switch feels nice and has niceties such as settable brightness:
Apollon Purifi 1ET6525SA ST stereo class D amplifier balanced XLR RCA back panel trigger review.jpg
That premium extends to no less than four gain settings (although I had trouble reading the tiny fonts). Not only do we have trigger input but also output!
In use, the top of the amp was room temperature and bottom only slightly above.
Apollon 1ET6525SA ST Amp Measurements
To keep me from going crazy, I focused my testing on XLR input only. For gain, I started with the lowest gain setting of 12.X:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 12.5 Measurement.png
This performance easily lands the amp into top 20 amplifiers ever tested (out of nearly 300):
Naturally, higher gain settings rob you of some performance but not much at 20.X:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 20 Measurement.png
Going to 27 does cost you though in noise department:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 27.5 Measurement.png
Fortunately 20 dB gain is good enough to push the amp to max power with nominal 4 volt input over XLR connection:
Apollon Purifi 1ET6525SA ST stereo class D amplifier 20 dB gain SNR Measurement.png
If you have a professional interface that can output more than 9 volts, you can opt to use the lowest gain:
Apollon Purifi 1ET6525SA ST stereo class D amplifier low gain SNR Measurement.png
From here on, I focused on testing at 20 dB.
Frequency response is load independent as we expect in this class of class D amps:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 20 frequency response Measurement.png
Multitone and 19+20 kHz show superbly low intermodulation distortion:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 20 multitone Measurement.png
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 20 19 20 intermodulation distortion ...png
Lower class class D amps really suffer in the above test. Not so here, leaving many class AB amps in the dust.
Channel isolation is superb as well:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 20 crosstalk Measurement.png
Available power in the sweet spot of what I recommend:
Apollon Purifi 1ET6525SA ST stereo class D amplifier low gain Power 4 ohm Measurement.png
Apollon Purifi 1ET6525SA ST stereo class D amplifier 20 dB gain max and peak burst Power 4 ohm...png
And doesn't change much in bass either:
8 Ohm naturally has less power but most speakers are 4 ohms or lower:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 20 Power 8 ohm Measurement.png
I tested its ability to drive one channel with 2 ohm. While it did that superbly, it did not result in a lot more power:
Apollon Purifi 1ET6525SA ST stereo class D amplifier Power 2 ohm Measurement.png
Our sweeps with respect to frequency show the common rise in distortion at higher frequencies. But this is still excellent performance:
Apollon Purifi 1ET6525SA ST stereo class D amplifier gain 20 distortion vs frequency vs power ...png
Power on noise is nonexistent but there may be noise on power off:
Apollon Purifi 1ET6525SA ST stereo class D amplifier power on noise off Measurement.png
Finally, the amp is rock solid on power up:
Apollon Purifi 1ET6525SA ST stereo class D amplifier warm up Measurement.png
The Apollon 1ET6525SA ST is a solid offering in premium module based amplifiers. It has done justice to the underlying Purifi module by providing superbly low noise and distortion. It has rich feature set in the form of gain setting, trigger, etc. With almost every speaker being happy with nearly 400 watts on tap, it makes for an easy and future proof choice. And a feature in the cap of our European members!
I am happy to recommend the Apollon 1ET6525SA ST amplifier.
Frequency Response: 0 – 50k Hz +0/-3dB
Low Distortion: THD+N – – 0.0002 % 20Hz-20kHz
High Input Impedance 100K
Signal to noise ratio: 131dB
Gain (dB) 12,8/20,5/27,5/29
Ultra High Damping Factor
High Current Output Max 25A
Power rating: 450W @ 2ohm | 425W @ 4ohm | 227W @ 8ohm
Case Dimensions: 305mm depth x 69mm height (with feet) x 250 mm width
Weight: 2.9 kg
I guess with this kind of performance (and other purifi and hypex based modules) it’s end game, like we have it for DACs.
What more do we want? Let’s focus on speakers to reduce their distortion!
Yep, that one delivers, not much to say.
Their Lux or premium line are more to my taste but I could live with that one as well.
Thanks Amir!
(at the danger that @Mort thought that someone hacked me, I do think that the "Apollon" mark is HUGE, and dominates more space than it should, it would be a deal breaker to me personally, plus ((edit after @JSmith 's insides)) I would prefer the speaker wires to be soldered at binding posts.)
Thanks Amir! You really are on a roll. The pace at which you are reviewing gear these days is really impressive.
Thank you Amir for such a nice review and such a good performer, fun to read.
It is a magnificent piece of engineering, but there is one specific feature that would make it even more competitive.
I recently noticed that other new amplifiers on the market, such as the Buckeye Purifi 1ET9040BA, have started incorporating Signal Sensing Auto Trigger.
I strongly invite Apollon to consider adding this functionality. Many users, including myself, pair these high-end amplifiers with gear like MIDI keyboards, pro interfaces, or streaming DACs that lack a traditional 12V trigger output. Having the amplifier wake up automatically upon detecting an audio signal is a game-changer for usability in both studio and home environments.
Adding this would bridge the gap and make the Apollon an even more versatile and 'complete' choice compared to the competition.
Yet another stellar product that is built around Purifi amp modules. Is the PS also from Purifi?
I second the idea by @F1308 to include an auto on/off (from standby) feature based on the audio signal input. It's very practical for the end user.
Which buffer option is used ?
I like the inclusion off both XLR and RCA conections, no xlr to rca cable kludge needed ( there are changes of getting these cables wrong ).
I think this is a must have .
Stellar performance ofcourse, if this is the amount of power you need , this amp is a strong contender
Thanks amirm for the great review, also thanks the member who sent it in for review.
It's good to see Apollon Audio amp not only measure well but also do value adding for their "budget" line amp by added the brightness adjustment switch for the power on light which is useful for light control HT room.
Agreed about the convenience and safety (which is above everything else)
But a properly made RCA>XLR cable shorting the (-) and ground at the source will always be much better.
Excellent performance. I am so close to order
A few days left for code XMAS25 for 10% off
What a marvel!
Thank You Amir !
It's a shame too. The rest of the case is so nice.
