Even this shows the schematic for the ES9038PRO, the ES9038Q2M also supports custom filters already up to 128 coefficients/taps (the ES9038PRO up to 256 coefficients), just need to load it to the registers see page 25 of datasheet.If you look at this functional diagram, where would you put your external filters?
Sold out now, on back order lolUp at Amazon 4 left $219 https://www.amazon.com/SMSL-C200-Headphone-Amplifier-ES9038Q2M/dp/B0B9391B45
The Ex5 can do this as well. It's why I bought it for my second desk. So I can toggle between speakers and headphones.The Topping dx3 pro+ and I'm pretty sure the dx5 have this feature. A button on the remote can switch between Headphone only, dac only or dac and Headphone out simultaneously controlled by the volume button.
Yea I am not sure I like their new design language.The box looks so fugly in comparison to the DX3Pro+ (which eventually should get updated to match the current DX like of 5 and 7+ I bet).
It's like SMSL isn't even trying to make the design as appealing as the numbers it puts out.
It is digital volume control as @amirm said a few posts above yours.Relay volume control?
What is it for?If you look at this functional diagram, where would you put your external filters?
Thanks, looking it up.The Ex5 can do this as well. It's why I bought it for my second desk. So I can toggle between speakers and headphones.
You'll have to ask restorer-john. He said if manufacturers where caring they should use external custom filters instead of the included ones. I was simply pointing out that it's not that simple.What is it for?
and balancedSo is this now the “new” standard to beat in terms of value ? Seems that $20 is justifiable for internal power supply and 1/4 adapter over the dx3 pro+?
And wow look at that remote that at least looks nice (reminds me of the Amazon fire tv remote) and it’s properly labeled. Someone should let topping know
The remote looks nice and the layout is logical. But the IR sensor is blocked from above, meaning it will not work if the remote is below the receiver level and the distance is low or the angle is odd. It's not a good design at all. Ask me how I knowSo is this now the “new” standard to beat in terms of value ? Seems that $20 is justifiable for internal power supply and 1/4 adapter over the dx3 pro+?
Multitone is naturally so as well:
and balanced
I believe that’s because Amir do his multitone test at 192 KHz and the filter we see is for 44.1… The technical reason to do the multitone test at 192 @amirm would have to say but those filters obviously get’s new coefficients as you change the sample rate. It does draw a nicer picture.If this was measured using the default filter 1 that's -10db @ 20khz, why doesn't it roll off in the multitone?
It looks mostly like they combined the HO100 and DO100 into this product for almost the same price...Yes this looks great value. It seems to have the same major components as the SMSL DO100 DAC with very similar performance. Only difference in features i can see is the balanced output is TRS in C200 vs XLR for DO100. The DO100 was rated an excellent DAC and great value a few months back. The C200 gives you basically that DAC for the same price but also includes a very decent headphone amp. ... unless i am missing something.
Yes. The performance of DO100 / HO100 seems slightly better but very similar. I recently bought the DO100. I think I would have preferred now to have C200 with basically a free headphone amp. I don't really need a headphone amp but it would be nice to have for future.It looks mostly like they combined the HO100 and DO100 into this product for almost the same price...
I almost bought 420$ Sabaj A20d 2022 version but decided to wait for some reason, the moment I saw C200 I knew this was the one and I pounced on it, cannot wait.Yes. The performance of DO100 / HO100 seems slightly better but very similar. I recently bought the DO100. I think I would have preferred now to have C200 with basically a free headphone amp. I don't really need a headphone amp but it would be nice to have for future.
