- Thread Starter
- #141
Digital.
Digital.
The Topping dx3 pro+ and I'm pretty sure the dx5 have this feature. A button on the remote can switch between Headphone only, dac only or dac and Headphone out simultaneously controlled by the volume button.I am still looking for a desktop DAC /headphone amp /pre, that can mute the line outs when you plug in a headphone, or with a button. Is it still unfeasible in 2022 with tens of iterations of basically the same product?
Better thd+n since the audio signal doesn't need to pass thru the resistor in the amp's volume pot.What would be the advantage of a digital volume control? Based on instructions for external DAC/amps to always max the PCM source’s volume before the DAC for allowing the amplifier’s analog to control the volume was standard practice(?)
Where in the chain between input & output would you apply digital volume control that wouldn’t introduce quantatization error?
I second this or a DAP just to expand their market. It's already know they can make a well engineered DAC/Amp at affordable prices.Starting to become boring all these dacs. I have one, I don,t need a new one every month.
My tip to topping/smsl/other excellent companies, please come with an aforadable roon ready streamer.
Then I am interested again.
That's the obvious other answer, but it costs *something*. AFAIK they all either push on/pull off of have a small grub screw located underneath so it's not visible in normal use.Can they also be switched out easily with an aftermarket knob, for instance my JDS Labs Atom with a deeper & knurled volume knob (definitely improved ergonomics).....it just slides on:
Also, amp gain that are more than +20dB are antiques that add more noise.
Technically awesome! Going to be hard to make a value judgement until price is known.
EDIT: Possibly coming out at $219.
Interesting… the next thing you know they’ll put PEQ on the DAC chip…
I'd say Filter #3 looks the best to me, as in no major roll off before 20kHz and reasonable attenuation after:
Almost none have any PEQ in the first place and is the reason I voted fine for this DAC/amp, which do measure very well.Wonder why the desktop products haven't implemented features like PEQ via a companion app the way a portable product like the Qudelix did (and for barely over $100)?
Good points about the filters, I agree. I think the product designers do care though, so I don't feel vehemently towards them.Filter 3 is the perfect one for sure. All the others are pretty much faulty out of the gate.
Honestly, this 'selectable' filter thing is just patent BS. If the product designers actually cared (which they don't) there would be proper, external filters that engaged for each sampling frequency, instead of catch-all f#ck up filters that are not remotely appropriate.
If you look at this functional diagram, where would you put your external filters?Filter 3 is the perfect one for sure. All the others are pretty much faulty out of the gate.
I think digital volume is a better option at this price point.Digital.
It is at any price point.I think digital volume is a better option at this price point.
As long as it behaves if you are directly connected to power amp/s - and doesn't have a glitch that makes it go to 0dBFSIt is at any price point.
