Anything that can compete with the WiiM ULTRA ?
Hallo.
Is there anything that can compete with the WiiM Ultra without an amp,
for under 500€ ? Anything out there for this price ?
Some options
Cambridge Audio MXN10
WiiM Pro Plus: If you do not need the screen, HDMI ARC, or phono input of the Ultra
Arylic S50 Pro+
FiiO SR11 + External DAC
Fosi S3 and S3 Lite were recently announced as well.
However, the WiiM is fully transparent and has by far the best App and the most active developer team.
So even if there is a competing product which has imperceptibly better noise and distortion, there'd be no point in putting up with the inferior App for that, since the advantage is moot.
The lack of XLR out is likely the biggest con (besides lack of AirPlay for those unfortunate enough to find themselves in Apple's walled garden), but even that can reasonably be worked around:
as a beginner, WiiM is probably a wise first step.
Wiim Amp Ultra has all you need Same amp board as 3e audio A7 (TPA3255)
Enjoy...
Hallo.
Raspberrypi , hifiberry dac8 , camilladsp, lyrion streamer, under 200€
If you're considering the Arylic route mentioned earlier, I'd actually point you toward their newer LP10 streamer rather than the older S50 Pro+. It's a very cost-effective way to get Google Cast and AirPlay 2. Just a quick technical note for anyone looking into it: the LP10 uses their newer "Go Control" app, not the legacy 4stream app. It's a much-needed step in the right direction for software stability. It might not measure quite as flawlessly as the Ultra, but for casual listening, it's a solid piece of gear.
