Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,220
- Likes
- 5,455
- Thread Starter
- #221
My dream system
What's that weight - half a metric ton?My dream system
Thanks. Unfortunately for HEDD and PSI, these horizontal and vertical polar measurements do not look nearly as good as Genelec or Neumann. Even the on-axis frequency response is pretty terrible at least compared to the ruler-flatness we’ve come to expect now from Genelec, Neumann, and others.
That’s strange you say that because I’ve listened to my Genelec 8351B in a medium/large room with dual 18” subwoofers to relieve them of any bass strain, and I find them some of the most “dynamic” speakers I’ve heard in this role for movies etc. I’ve heard in this same room JBL SRX835P’s which are capable of pushing 135db at least on paper, and did not find the Genelec’s insufficiently dynamic at all. I much preferred the Genelec’s, even for movies as well as loud music. I do like to listen loud sometimes, but maybe other people listen way way louder than I do? I’ve pushed 115db overall (mostly from a bass weighted tuning), but anything beyond that my ears do not tolerate.
Nice room. Do you have any measurements for your speaker, to compare with KH310?
Custom tops made by a local company here. FaitalPRO HF1440 in an18sound XR1464C horn 1st order crossed at 1kHz to 4xScanSpeak 15WU's. Everything's powered by FA253 plates. Changed the ADI-2 Pro to a Pi2AES streamer and now I'm using the AES/EBU connections.
When I did the testing you quoted, I used dual Rythmik F18’s because I was comparing the Genelec’s to Revel Salon2’s (otherwise it would be unfair to Genelec because the Salon2’s have bass power comparable to dual 12” subs) but right now I just use the Genelec’s for a home office music and video games setup, so I use the Genelec 7360.Which subwoofers do you use with 8351B?
What do you want to know? It's a DSP speaker, so AFR is pretty much what you want it to be. I was present when the acoustician used SMAART to adapt both speakers to the room, so I know it was flat enough.Do you have any measurements for your speaker, to compare with KH310?
Which brand and/or any specific speaker / monitor model is better than Genelec and especially the Ones?
On and off axis FR, polar plots.What do you want to know? It's a DSP speaker, so AFR is pretty much what you want it to be. I was present when the acoustician used SMAART to adapt both speakers to the room, so I know it was flat enough.
I don't think there's anything exotic going on. The directivity above 1Khz will be dictated by the horn -I suspect exotic speakers to have strange directiivity
I don't know about your definition of the refined quality... personally I have no issue listening to them for 3 hrs continuouslyMeasurement aside, do Genelecs have a "refined" quality to them that allows long hours of listening in the way that Dynaudio does, for example?
Some people find them bright but i think it's only because people are used to less detailed monitorsMeasurement aside, do Genelecs have a "refined" quality to them that allows long hours of listening in the way that Dynaudio does, for example?
And with GLM you can change the high frequency roll off so this is a non issue.
No they do not. That is exactly what is missing.Measurement aside, do Genelecs have a "refined" quality to them that allows long hours of listening in the way that Dynaudio does, for example?
Sorry I do not agree unfortunately. I have a Genelec 5.2 setup and I listen to them the whole day at different volumes without getting tired and so do the different sound engineers/music producers around the world who work all day long. That being said, my room is not professionally treated except for couch and some curtains that takes away some reflections.No they do not. That is exactly what is missing.
