Anyone Review Topping D90III Discrete / D90 III Sabre yet ?
I have had cases of faint ticking on multiple components that seems to be caused by RF of some kind.
The Oppo Sonica DAC did this until I moved it away from other components.
- Rich
Agreed ..Ticking sounds like it's probably WIFI interference to me. Lots of folks have their wi-fi within a foot or three of their components.
It does not sound the same in my system.
Roon->Raspberry Pi5 Pi2AES->D90III Discrete
Just to make sure you were playing native DSD512 (and/or DSD128/256 with DSD Bypass ON) in DAC mode and no PEQ?
I'm told the D90 Discrete has extremely low jitter via USB. AFAIK the Pi2AES uses dual NDK NZ2520SD which typically have phase jitter around 0.2 picoseconds. The difference should be well below audibility thresholds IMO.
If I2S still sounds different to USB then the Pi2AES or Topping messed up somewhere.
There may be solid reasons the inputs do not sound the same. Jitter is only one of these.
If we assume jitter isn't the reason, could you elaborate why USB and I2S sound different when playing DSD512 natively (without conversion) on this 1 bit DAC?
It would be surprising if level matched coax and AES always sounded the same. Most AES transmissions have pulse transformers on input and output.
The reviews test for jitter and coax matches USB. Optical tests a little worse usually. Few tests for AES. I2S even fewer tests.
Are the measurement differences in the audible range?
- Rich
Thanks...You guys were right--I had my DAC sitting directly on top of my streamer. By gapping them a couple of inches using some, "hi-fi isolation feet," I was able to eliminate the ticking noises.
Appreciate the help!
Are the known problems with the D90III Discrete (clicks, wrong volume) are resolved with the latest firmware now?
Apart from the price, can this device be recommended without reservation?
I've had this DAC for a month now and haven't noticed any issues. What I don't quite like is the output level and, I suppose, the output impedance. I use it with a Gustard P26 preamp with an input gain of +6dB, so it's one of the best DACs I've ever heard.
Haven’t had issues with mine either; I use the 2.5/5V output setting to my B200s in high gain and it is plenty loud (low gain on the B200s is just a little short of the volume I want on some quiet tracks). I only send PCM though, due to my room correction being an absolute necessity.
Most, there is still an issue with the I2S with DSD is low volume and incorrectly reported as 176K pcm.
- Rich
Hello everyone,
I've got Topping D90 III discrete, and it has two power output options for XLR - 4v, and 5v. Can someone please explain how can choose to switch between?
THANK YOU
Hello everyone,
THANK YOU
5V will lower the noise floor compared to 4V, but if you find your volume control is very limited due to excess gain (like even on your quietest tracks you are only using like 1/3 of your volume range), you may consider 4V just to help improve volume control granularity. Generally speaking, better to use 5V if your system is fine with it.
If you're using amps with adjustable gain, set them for the lowest gain and use the highest voltage at the DAC (5V) to achieve the lowest noise floor. If the gain is limited or no adjustment on your amps and very high (+26dB or more), you may find it better to use the 4V setting just to get finer volume control.
I want to use 5v out, but I don't know how to switch it from 4v to 5v? I can't see a dedicated switch for that. So I am asking maybe someone could clarify how is this done on this dac?
Thanks in advance for help
There’s a power switch on the back, next to the power connector. Switch it to off. Now press and hold on the control knob on the front while switching the power switch on the back to on again. This will put you in the setup menu where you can change numerous settings including output voltage as well as DAC only versus preamp mode.
