Anyone Review Topping D90III Discrete / D90 III Sabre yet ?
So why are you here trying to engage?
I’m here to engage with other D90 Discrete users and share real-world experiences with this specific unit. That's why I'm in this specific thread rather than all over the forum. I’m looking for a dialogue with people who actually use the gear, not a lecture on signal theory.
Believing my own ears, having a revealing set up, seeing consensus among the many reviewers and the strong belief that a company doesn’t spend a lot of research money to produce the same result time after time after time leads to a verdict: come on guys, wake up.
What reviewers? What credibility do they have, as opposed to any other random on the internet who "believes their ears"? They are shills for the same industry selling you these gadgets.
If a difference between competent DACs is "easy to hear", you are not hearing a difference between DACs. It's really that simple.
If you think a DeltaWave null test with music captures every non-linear artifact, intermodulation distortion, or power-supply-induced noise floor modulation that a resolving transducer can reveal
Everything that could account for "easy to hear" differences? Yes, absolutely, I've never seen the faintest shred of evidence to the contrary nor even a plausible hypothesis. A good ADC, like a good DAC, is orders of magnitude more "resolving" than any transducer.
You need to spend some time reading and understanding the works Prof Dianna Deutsch.
I’m familiar with Diana Deutsch's research, and I’d suggest you revisit it with a bit more care, perhaps starting with the spelling of her name. Using her work to dismiss firsthand listening experiences on a specific signal chain is a bit of a stretch. I’m sticking to the topic of this thread the D90 Discrete.
SoundWeird has a point and I have often wondered this myself - how do you measure soundstage width, depth? Is the science of measuring complete? It seems some think so...I'm not so sure it is definitive, there is always room for improvement...no? So please give the guy some space - he is just asking for subjective opinions.
Soundstage from a dac will be represented in the same way as any other audible quality must: voltage varying over time. If the only differences between two DACs in this regard are differences that you can straightforwardly verify do *not* produce such effects - like minor frequency response differences - the DAC cannot be responsible.
Interesting. So let me ask you this - Is there any signal leakage between left and right channels in a DAC? I think this is called interchannel crosstalk. Low crosstalk usually helps maintain good stereo imaging. Or is crosstalk in the realm of the preamp/amp? Just trying to find where that would originate. What about phase and timing coherance? Phase inconsistences can smear transients and collapse spatial cues. Again where would such artifacts originate?
Look I'm retired and my career was in IT - managed Oracle and SQL server DBAs for a defense contractor. I know IT but I don't know much about electronics and acoustics, trying to understand how these things tick. You guys are making the DAC seem like its a no fault device (assuming a technically good design). If that is indeed the case, then I suspect the perceived differences are subjective and might differ due to biases. Or perhaps its the human listener - head shape, ear geometry, listener expectation and focus.
I believe folks hear and perceive sound differently...and you believe the DAC is not at fault.
Yes, crosstalk exists in all devices in the audio chain. It's usually irrelevant in line level parts like DACs and most preamps. Amir does not measure it for DACs, but does so for preamps. You won't hear crosstalk at -100 dB. Even at -80, I would be sceptical, especially if it's outside of the most sensitive region of hearing.
As explained, it affects all devices but relevant levels of crosstalk can usually only be found in power amplifiers. I would assume that the reason is the much higher voltage found in amps, which causes the electromagnetic field in the PCB tracks and cables to extent much further.
Why would phase changes "smear transients" or "affect spatial cues"? If you select a minimum phase filter on a DAC, it sounds the same as the corresponding linear phase one. However, the phase/frequency relationships of both filters look quite different.
As far as I am aware, phase isn't usually of concern for audio reproduction. Heck, for the majority of recordings, it's not even clear if their phase has been flipped at some point during the mastering process. We all listen to phase-inverted music all the time and nobody can tell.
Folks also believe that there is an audible difference if they switch power cables. People are subjective and believe the most ridiculous shit. Doesn't make it true.
Oh very true folks believe all kinds of stuff. But it is also true that folks perceive sound differently, what one hears doesn't make it universally true for all. You have a measured effect, we know it is a pure but folks will receive and interpret that sound differently. That's all I'm saying.
Insofar as DAC's. I suspect a $200 Topping solid state DAC will sound differently than say an Audio Note DAC 0.1x tube DAC. They are both competently engineered but will sound different. Some DACs just don't sound the same.
Nothing audio note is competently engineered :) you might have picked just the one off the few where there is possibility to sound different, but not for a good reason.
But there is no difference to perceive if the signal is identical. That's the point of precise measurements.
Yes, two people will subjectively ascribe all kinds of qualities to audio devices. The next day they may describe them differently and then different again after a glass of wine. That doesn't mean those devices actually sound different from day to day. It's just means people's senses are unreliable.
A tube DAC is not "competently engineered" in the sense that wording is commonly used on this forum. The job of any DAC is to translate digital signals into the analog domain as precise as possible. If it doesn't do that, it's not a good DAC. For DACs, "well engineered" is usually equivalent to "audibly transparent" around ASR. And if two DACs measure audibly transparent, they by definition will sound the same.
You can design and build all kinds of flawed DACs and they will not measure transparent and may not sound identical. That's undisputed.
OK fair enough...that makes sense.
How would this play along with Eversolo T8 you think? I'm kinda undecided between Topping and Eversolo Z10...
Edit: Yamaha A-S2100 is my integrated amp with KEF R500 floor-standing speakers.
There will be no difference in SQ, I used the T8 with the Z-10 smart boxes shame they didn’t have the same external dimensions.
I got a Topping U90 (wow not easy). Was hoping and thinking IIS would be plug and go with the default settings between it and my D90iiiD, but nope. :-/
Some signaling is getting there - when I change the sample rate on the PC and hit 'test' I see it change on the DAC, but no sound. Sound works fine over AES, so all the rest of the path is fine.
I'm going to try to find another cable to test with (though this one is specifically a "HiFi IIS cable", though I'm sure I was just scammed and it's just overpriced decent quality HDMI), but just wanted to throw an ask out there - any obvious gotchas I'm missing? I've compared the pinouts in the manuals for the two units and they're identical - checked the settings multiple times and they match. The only thing there isn't a setting for on the D90 that there is on the U90 is -
but I've tried both and neither works :-/
and in case you're going to ask why I can't just live with AES -
Edit - Just flipped all the settings backwards on both ends for S&Gs (poops and laughs), and it works ?!
Edit2 - Actually seems like it was the IIS Mute setting which I flipped from low to off at the same time. When I flipped it back to low, no sound again. I turned it back to off and flipped all the other settings back to default, and I am getting sound. So, something about that IIS Mute setting not working with a U90 - as far as I understand, it's supposed to mute while changing sample rates to avoid some noise you would typically get, but it seems to just fully mute? Either way, crisis solved, huzzah.
Anyone knows 3rd party measurements for the D90 III Discrete?
Reactions: MBO
Topping don't make up their measurements, if you compare Topping measures to Amir's measures they are essentially the same.
They both use the same Audio Precision measuring equipment.
Yes Topping use A weighted measurements and maximum output voltage over XLR, Amir only chooses to limit output voltage to 4 volts to create a level playing field. Most users run with highest output voltage for maximum sonic benefit though.
That only stands if they use the full output, not attenuated at all.
If not and they use more attenuation than the lower setting the measured results will be overall worst.
(and I suspect no sound quality is affected either way except if attenuation is too much, that has a long road ahead)
