Tks
- Joined
- Apr 1, 2019
- Messages
- 3,221
- Likes
- 5,497
I get that you don't get 4W of power produced out of the headphone for example due to efficiency and resistances, but..
I have no issues taking HD650's or HD800's and having them run out of the IEM port on an RME DAC (this doesn't get me to 2mW on a 300ohm load according to the review of the device). Now there is some music with higher dynamic range, and the quiet parts I can see maybe wanting sometimes to go and get some more volume, but I really don't understand what someone would need with like the output power of some of the new AMPs from SMSL and Topping. I get theirs very inefficient headphones. But really inefficient enough to drive output beyond even 4V for instance (taking a Ether CX situation for example)? I've sampled them, along with others in the 600 ohm range, and I just don't get what music people regularly listen to, to where you would expose yourself to 30 minutes of something like an eventual 500mW+ or more of power? I've got a bunch of classical music with some tracks that have MASSIVE dynamic range swings (actually pretty bad, it's so massive, that to hear the lower parts really well, your volume would need to be so loud, that the higher parts are unbearable). So discounting some of this stuff that isn't pleasurable to listen to in almost any situation - are their any other kinds of music where you're driving both your DAC and AMP to it's near max? What headphones do you use if you're one of these people?
