analogonly
- Joined
- Oct 8, 2023
- Messages
- 72
- Likes
- 83
High phase angle with low impedance.Why is that ? In what way is it hard to drive? What special or unusual requirements does it have?
FWIW, a pair of Nilai monoblocks make the Magico A5s sound fantastic, to my ears. Can't expect any different from the fabulous 9040s.Hi, All, new to the forums. I heard all the positive reviews and opinions on newly Class D amplifier such as Purifi 9040. Just wonder anybody use it for expensive speakers such as Magico, Wilson Audio.
I have had numerous 'low cost' Class D amps that have lasted nearly a decade now, some longer, including an Icepower board that runs the speakers on my PC and has been powered on almost continuously since 2012 with zero hiccups. I suspect this common trope of "not built to last because cheap" is going to fall by the wayside soon.There's still of course a difference in build quality, cooling (effects life span), and service. And there can also be a difference in features and the quality of these, i.e. the accuracy of a gain control.
Most low cost class D amps are not really built to last.
Depending on how you define "low cost," most things defined as such are not really built to last.Most low cost class D amps are not really built to last.
The focal scala utopias I am driving with the hypex aren't that easy either for the same reason. I do, in fact, have a couple of older amplifiers where I noticed and measured a difference. But I haven't had any complaints with the hypex and purifi is supposed to be somewhat improved.High phase angle with low impedance.
See my reply above.Someone with Magico speakers is going to have to try this and report back to us. I am curious.
I would say especially low output impedance amps feel the speakers more, they're just so strong, they simply overpower their imperfections with brute force.Well... if it had a high-ish output impedance, it would feel the loudspeaker's wacky, if not downright perverse, impedance and phase curves.
Absolutely. It has nothing to do with class D but the built quality as mentioned. Same can be with other classes, and which we see with some of the lower cost from China.It could be argued that no low cost amp is designed to last - nothing to do with its !Class".
Certainly over the last 30 years or so Class D (alone amongst audio technologies) has improved unrecognisably and therefore old Class D amps fall by the wayside as newer and better technologies have emerged.
Now that the best Class D can match or better any other amp technology, it must be taken as seriously as digital cameras have been taken seriously after a poor start in the 1980s. Who buys film cameras now?
Even there the 9040 does well with its 40amp max output I would say.amplifier designers responded with monster "arc-welder" devices
Class D is objectively way more effective though, and even if they are "only" mounted onto the bottom of the chassi many of them stay cool no matter how hard you push them within their power range.Absolutely. It has nothing to do with class D but the built quality as mentioned. Same can be with other classes, and which we see with some of the lower cost from China.
However, what we're seeing with the newer class D modules is often an overlook of the need for cooling. Modules are typically mounted in a bottom of a chassis instead of mounted directly on to heat sinks or the use of a fan. The result of this, and as restorer John has shared on this forum, is early death of components due to overheat. Obviously it depends on the environment they are in and how long they are turned on, but these are not build to last under various conditions.
A few companies make class D with proper cooling though and they should last a long time.
Two pages and it looks like no one has done class-D & Magico. Mostly opinions. Hmm…
That's why I suggested the Marantz Model 10, based on Purifi.Could it be that Magico owners are too snobby to even consider Class D?
If you have spent bonkers money on a pair of speakers, why not spend a bonkers sum on an amplifier. Since Class D is relatively inexpensive, these amps are not likely to be on their radar!![]()
By the way, I'm using B&W 800 series speakers with Class D. Is that high end enough for you?
