I don't hear much, if any difference between 320 kbps MP3 streams and standard CDs. I consider myself blessed in this respect. I don't think there is an audible difference. And, I don't mind saying so. But, if you hear a difference, what is it?
This was another track used to develop MP3.
High bit rate MP3 is almost transparent but not 100%
You can provoke this by using the "killer samples" e.g. https://hydrogenaud.io/index.php/topic,77128.0.html
@amirm has reliably discerned a difference in ABX testing if I'm not mistaken...
I hear it too on this. I don't think that much is on the original CD. But hey, encoding obvious distortion can still distort the result.Her voice had a lot of natural distortion. I can't see how this would not affect comparisons
I just did it on a sample I picked out. Ask J-J firstly mp3 was never claimed to be transparent. It has been tested and it isn't. It has gotten better, and it is very good, but it is discernible. Do we really need to test this again?But who can REALLY tell the difference and validate their claims. This should be an open-and-shut scientific case. Something amiss here. Is it lack of DBT trials or 'I can hear it' protests with no substantive back-up from that camp?
'Round and 'round we go ..................................... .
FWIW,
I never use low resolution for music in my home, but when I play music in my car, I have experienced on many occasions that music from the radio (DAB digital) sounds «unclearer» than the same music from a Tidal 16/44 stream in the same car.
So I wondered if a somewhat higher quality music stream is practical in a car where you have lots of other noise in addition. Does that make sense?
Maybe due to the background noise, I experience less fatigue playing 16/44 than DAB digital radio. I can also play on lower volume.
Where I'm at, digital radio is encoded to 96kbps AAC,
furthermore, some FM radio stations (public announcement radio) use high quality audio as source, other commercial radio might have a gimmick set-up of their own which can definitely use some lossy source (which is quite apparent...) and gets then re-encoded which will of course sound like ass.
So yeah not every radio station will sound the same, you will have differences in how they are set up I'm sure.
