I understand that, but I have the distinct impression that energy efficiency is improving at a faster rate than the need for more speed.
Over about 5 PCs, my CPU temps have been the same for two decades, despite large improvements to efficiency. That is because chip makers are constantly pushing the performance they can get out of each chip's thermal envelope. To not do so leaves performance on the table. Certainly Intel can't afford that with how strong AMD has been, and now Apple, ARM, etc.I understand that, but I have the distinct impression that energy efficiency is improving at a faster rate than the need for more speed.
There is a consumer solution for this for custom loops from aquacomputer called the leakshield (a pain to get as it's always out of stock):Negative pressure liquid cooling
More about it here:
And here:
Data Center Cooling Technology | Liquid Cooling Solutions
An efficient direct-to-chip liquid cooling system that reduces data center operating costs and eliminates the risks associated with liquid cooling.www.chilldyne.com
Oh, it's definitely not passive. The continuous load is at least 700W when "idle" (cryptomining when they aren't being used) and even higher when it is being used on other tasks. The tank itself will be connected to an external radiator setup. Specifically, there will be a pump circulating the heat from the top of the tank on one side to the bottom of the tank on the other, and in between this line will be a small brazed heat plate exchanger.
Then, connected to this heat plate exchanger will be a typical external radiator setup with another pump. The rad will have 200mm fans running at low rpm, which is virtually inaudible. I will probably be using two of these even if I don't do this immersion project because I like the silence regardless and can use it with my existing loop:
Its possible to run the dielectric fluid directly from the tank to the radiator like a typical WC loop, however this is a lot of unnecessary volume of dielectric fluid (which is expensive). So a plate exchanger in this situation is ideal so you can use cheap water/glycol coolant on the air exchange while keeping the good stuff in the tank.
In the winter, the 700W+ load will be some very nice, silent, passive heat for the home. In the summer, the versatility of the external radiator can allow me to dump the heat outside without heating up my space further. I've seen people do interesting things like use the waste heat from their setups to do things like heat water in their homes or for under-floor heating, or even using running water from indoor tap/plumbing to cool the system with a heat exchanger in places where water is cheap or virtually free. I know a guy that personally dumps all his heat from a 30KW immersion setup into a nearly lake on his property and circulates the cool water from the lake back up to his shed. It can be scaled up pretty easily and the heat exchanger can be as small as a PC radiator with fans to an industrial dry cooler.
The setup I described is really not much different from traditional watercooling. It's just that instead of having multiple waterblocks and connections between components, everything is just submerged in tank and the only connections are between the tank and however you're exchanging the heat.
The heat being dumped elsewhere isn't really a feature of the immersion setup, it can be done with any traditional watercooling setup with an external rad and it's currently what I do now already. I would be lying if I said the novelty of an immersion setup and my own boredom wasn't part of my motivation to do it. While its not really "necessary" for a single PC setup I definitely hope to eventually convert the rest of my rendering/mining machines (with many GPUs each) to a larger immersion setup purely for the sake of quietness, cost savings, life of the components, and efficiency in the heat exchange. So really I am just thinking about this as an experiment that I will continue using and also further scaling up in a larger setup if I don't find it to be too inconvenient for my personal computer. Even if it has the potential to be moderately troublesome with a personal computer, the benefits for something like a server or rendering machine significantly outweigh the negatives.I just can’t understand why not go the traditional route then. I imagine any issues with any of the units of hardware, become annoying as hell to manage.
I read you find it nice being able to dump the heat during summer and all that, but this can be achieved with relative ease using hoses hooked up to a window and whatnot if need be.
I simply don’t understand the benefit of this full immersion setup especially so now that you explained it will be active.
I always chuckle when I see this picture making the rounds.
