Forman
- Joined
- Jul 24, 2019
- Messages
- 13
- Likes
- 21
Were you on Xtremesystems?
Oh yeah. 3dmark, superpi,, Winbond BH5 torture, DICE, LN2 ... Overclocking and diy extreme cooling is how I got into physics and electronics.
My time there slowed down after about 2007ish, but it was a great forum.Oh yeah. 3dmark, superpi,, Winbond BH5 torture, DICE, LN2 ... Overclocking and diy extreme cooling is how I got into physics and electronics.
I've serviced a bunch of audio gear with water, coca cola, orange juice and whatever else they spilled so I've seen the damage from them. It's impressive that you saved the underwater cameras and notebooks. From what I've read the glycol mixture is not conductive but I would not rely on that because like you say disconnect from power ASAP.As far as damage goes, it is going to depend on what the coolant is, and how quickly you get to it. I have saved flooded underwater cameras by keeping them soaking in freshwater until I could get them somewhere they could be dried out properly, and I have saved more than a few laptops after they have been given a cup of coffee (or in one case a strawberry flavoured protein shake) to drink, by getting the motherboards out and into clean water as soon as possible. The main thing is to get any power source disconnected as soon as possible, and to get whatever has got onto it off before it can do any damage - you would be amazed at how fast something as apparently innocuous as sugar can eat away at a circuit board.
Is that distilled, water mineral oil etc?
If memory serves me correct I've replaced a CPU or two due to coke spills. The stuff must be conductive. Nasty stuff for sure. My favorite excuse was the planter ring on top from where a fern(example) was placed on top of a receiver and then over watering the plant caused a spill. I've seen that a couple of times too.Coca Cola is lethal to anything electronic, is is so acidic that I don't like to think what is doing to my stomach. The laptops that I was able to rescue were the ones that were bought to me straight away.
Myself I have my notebook on the far left side of a 6 foot desk on a stand and the desktop PC is unreachable from the front of the desk on a riser too and I never put my beverage glass on the left side. I would be so embarrassed and angry with myself if I damage my own gear with a spill. It looks pretty idiotic if a electronic tech spills crap in gear. It’s a “secret sauce” (but mineral oil would do too).![]()
Almost decided to go this route with electrocool to cool a number of GPUs that do simulation workloads and crypto mining all day. I'm still keen on doing it, but maybe when I go back to Canada where I can really benefit from having a heat exchanger outside in winter and cheaper shipping from the US. Shipping all that fluid to Oceania was also quite expensive which deterred me. I was thinking about doing a 15-20L test run with my own personal machine just a few weeks ago.20 years ago, when I was into overclocking and building custom watercooling rigs, I had a friend who dabbled in full immersion cooling. I can't remember which dialectric fluid he was using, but I remember it was expensive - over £50 for 500ml. Anyway, full immersion cooling is a lot more common in DCs now... https://www.engineeredfluids.com/
Pedant alert!
Firstly, basically all consumer CPUs after the Pentium 4 era have integral thermal throttling. They slow down rather than kill themselves. It's fairly common to see laptop chips bouncing off their limiters at 105 degrees, because the cooling is not intended for sustained peak power. In a desktop setting you can and should do much better!
Secondly, the phosphoric acid in cola is less acidic than your typical stomach content. The mucous lining is intended to allow high acidity to sterilise and hydrolise food. Then your gall neutralises the acidity and pushes it alkaline as it transits to the intestines. As such I think the stomach can handle some cola, unlike your dentine!
Lastly, the conductivity of deionised water is very low, but it doesn't take much material at all to turn it conductive. As such it's a poor choice for immersion cooling.
Do carry on!
Idk about whatever this dialectric liquid is, but if it's anything like mineral water - don't bother, it's more trouble than it's worth, and the performance simply isn't there once the entire solution reaches steady state. Unless of course you plan on having a large tank big enough to never reach a high thermal soak quantity. But even then, there's the issue of circulation not being adequate. You also have maintenance issues (the liquid somehow naturally gets grimey eventually)Almost decided to go this route with electrocool to cool a number of GPUs that do simulation workloads and crypto mining all day. I'm still keen on doing it, but maybe when I go back to Canada where I can really benefit from having a heat exchanger outside in winter and cheaper shipping from the US. Shipping all that fluid to Oceania was also quite expensive which deterred me. I was thinking about doing a 15-20L test run with my own personal machine just a few weeks ago.
These newer specialty dielectric fluids are quite a leap from the typical mineral oil immersion in terms of longevity and other characteristics. They can easily last 5-10 years or longer and come with warranty for that long if desired. Performance wise, it may not be that much greater than a typical high performance water/glycol cooling loop but it offers lots of distinct benefits on top of marginally better thermals, namely cost savings. For example, I plan on always buying at least 1-2 of the latest/greatest GPU available every generation, and spending money on water blocks is not necessary with an immersion setup. Buying waterblocks and a few sets of good thermal pads over the life of the fluid will easily cost $2000+ for a couple pairs of gpus over that time period. There may be unforseen CPU socket changes which now needs a new CPU water block which further adds more to the cost. The fittings and hosing/piping for all those blocks also have a cost, and blocks should require semi-regular maintenance which also takes time and effort, coolant swaps etc.Idk about whatever this dialectric liquid is, but if it's anything like mineral water - don't bother, it's more trouble than it's worth, and the performance simply isn't there once the entire solution reaches steady state. Unless of course you plan on having a large tank big enough to never reach a high thermal soak quantity. But even then, there's the issue of circulation not being adequate. You also have maintenance issues (the liquid somehow naturally gets grimey eventually)
Also, kiss all those parts goodbye if second-hand sales are ever a consideration.
