- Thread Starter
- #21
I'm gonna have to give up on that by the looks of it, I checked the specs on the scarlet, -81 dB THD+N on channels 3 and four.Not if you want five channels
I returned a Creative AE5 after hearing the hiss on the side channels, absolute garbage... or you just don't worry about the cheap DACs
OK, I used for several years and didn't have this problem. Perhaps a lot of this has to do where the card is placed and into which motherboard and maybe also depending on the quality of the PSU. I always placed mine at the bottom, as long distance from the GPU as possibleI returned a Creative AE5 after hearing the hiss on the side channels, absolute garbage.
I had it on a Z87X board a few years ago, the onboard sound card had no hiss. I don't recall what slot I had it but doesn't it have a shield for that?OK, I used for several years and didn't have this problem. Perhaps a lot of this has to do where the card is placed and into which motherboard and maybe also depending on the quality of the PSU. I always placed mine at the bottom, as long distance from the GPU as possible
I don't know the specifics of that motherboard but with AMD AM5 I've had three different brands: Gigabyte, Asus and now MSI and they all have their own unique sets of bugsI had it on a Z87X board a few years ago, the onboard sound card had no hiss. I don't recall what slot I had it but doesn't it have a shield for that?
Edit: the specs says it has Soundcore3d for the side channels whatever the hell that is!
Seems to be, so you already have Creative card on the mobo
Creative Introduces Sound Core3D
Whilst not terrific it's similar to an amp like smsl a300 which many have not heard hissing... I'm still inclined to think that if one channel is worse then it's some form of bug, incompatibility.
Sampling rate, resolution and output converter (DAC) noise:i have been using this marvellous device https://www.amazon.com/AXAGON-ECO-ADA-71-Sound-External/dp/B0774MRT8F
it was dirt cheap and i hear no sonic quality difference from my 90s denon or sony cd- players![]()
