After a decade or so, I'm getting the urge to upgrade my desk setup. Back in the day my goals were basically "decent for the money" and budget room correction. I went with a pair of MK Bookshelf-75 speakers (on stands to get them mostly above my triple monitor setup), a Paradigm PW-Amp for ARC (knowing it's a pretty garbage amplifier, but it was cheap power and room correction), a Dayton Sub-1200, and a DX3 Pro. I use it for general listening - streaming shows and movies, music, etc. Pretty much all nearfield, though I move around a bit.
I want to replace the PW-AMP most of all, as its noise floor is ludicrous and it has various other frustrations. So I'm looking at getting a minidsp Flex and a pair of Fosi V3 monos. But I've also realized my 12' x 17' room has entirely predictable massive nulls at ~47 and 33Hz, while combine to kill most of the bass at my listening position. So I'm thinking that two subs are also going to be basically necessary in this room if I want real bass. Fortunately I have a spot diametrically opposite my existing sub spot that should work, and in theory should prevent those massive first-order nulls from forming. I'm thinking of upgrading my primary sub to a Rythmik L12, and adding a JL Audio Dominion d108 on the back wall. The JL doesn't go as low, but it's flat to about 30Hz, which should be more than enough to deal with the room modes, and it's nice and compact. The L12 can handle the really low frequency stuff, is extremely fast and accurate, and should have more than enough power for my uses, even below 30Hz where it'd be acting alone. One other reason I chose the L12 over some other options is that I have a fairly narrow space on the wall to put it, sandwiched between my desk and a couple PC towers. The slot itself is about 18" wide, but I wanted to leave a bit of a gap, and wanted to avoid any side-firing subs, which cut out a few potential competitors.
I figure I'll buy the L12 first, and temporarily stick it in the back location just to test the theory that these locations do work in the room, before I buy two subs that potentially aren't better than one. (With everything else in here there isn't a lot of flexibility in terms of placement, but I think these being on opposite walls, roughly the same distance out from opposite corners, should in theory work well.) It's also possible I won't mind the size of the L12 there, and I'll just choose to go with two of them. If it does feel a bit large in the spot though, which I think it will, the d108 should fit there nicely being at least a couple inches smaller in all dimensions.
And finally to round it all out I'm thinking Kef LS50 Metas to replace my MKs. I really want to hear this coaxial directivity magic in person in the space I'm used to. And since they're sitting on stands on the back corners of my desk (which is a sit/stand adjustable thing), I don't want to go with something giant, so these are toward the large end of what I'd consider. They should have no problem crossing over at 80 Hz though. (The subs will go to 80 easily, it is possible they could struggle with another room mode at ~70Hz and need some help. Not sure the Metas will do much there.)
So in summary,
Current:
DX3 Pro, PW-AMP, MK Bookshelf-75s, Dayton Sub-1200
Planned:
DX3 Pro (headphones only), MiniDSP Flex, Fosi V3 Monos, Kef LS50 Metas, Rythmik L12, JL Audio Dominion D108.
Starting with the Flex and Monos, then adding the L12, then the D108 (or second L12) and the Metas.
But choosing what to get is at least half the fun, so I don't mind circling around it a bit more before taking the plunge. Any changes I might consider? The only speaker I keep coming across that could be considered a direct upgrade to the Metas in the same vein, without being larger, would be a Genelec, but that's at several times the price, and I think overkill for my uses. (Besides need to leave something for when I'm itching for another upgrade!) But for now, what would you do differently? Or if you just want to praise my discerning selections, I'll take that too.
So in summary,
Current:
Planned:
