Any significant upgrade from 8040BPM?
monochiro
Hi everyone,
right now I am using an ADI-2 DAC FS together with two 8040BPM speakers. Are there any significant upgrades I could purchase, or is getting a subwoofer the way to go? And if the latter were to be the case should I just get something like a 7360 APM?
Thanks.
I upgraded 7350 -> 7360 and it might've been more flexible solution to buy a 2nd 7350. Depending on your room size and preferences on how much bass do you want, 2x 7350 with 8040/8340 is an option to consider.
Acoustic treatment, probably the biggest upgrade to your sound system. What kind? Depends purely on the room and preferences on how your room should sound.
The 7360APM is a great sub which works really well with other Genelec monitors, both analog and DSP based. The best upgrade to get, by far :).
7350 with 8040
The 7350 doesn't have analog bass management, so not good with 8040b.
I see, thanks for your replies. I will try out the 7360APM then.
