Currently I use Wondom JAB5 for a stereo 2 way system (each ch separate amp) 4x100 W on 6ohm. I use it mainly with bluetooth AptXHD.
I use with the PCUI software but for that the ICP must be connected ALL TIME!
I must say it is quiet noisy.. (ok I use with 100dB+ selenium D220Ti in Horns and B&C 8NDL51 94dB).
I love if for music..
They also released JAB6 with is TPA3255 2x so 300W on 4 Ohm if you can power it (48V).
What is yet unclear to me how these addoncard work. It got quiet a price bump, (but still a lot cheaper then any other 4 ch +dsp).
Question if it works with DSP AND bluetooth together or are those different cards and you need to choose
Then there is also a bluetooth reciever, and I would use the DSP but that is like 150€ ish...
I also considered Hypex FA 253 or 503 (only the fan though..) but I wouldneed 2 of those (plan to add bass driver to the 2 ways to make them 3 way full range). that is 1400€.. ouch.
I have seen the Acoustas 650 which looks also nice, but pricey for my build.
I also have 2 BRU5 (no ICP5 needed use different software).
Could also work well.
I am currently thinking to make a passive crossover (or leave is active crossed).
So your luck is that today there are a lot of options for a 2 way... but if you want 3 way.. that is a diffement anymal...
JAB 5 and 6 are also daisy chainable (so you can get more amp ch-s and still have DSP controll over each).
Maybe I will try a JAB6 next time hook them together with the JAB 5 , bridge those for subs or any other combination.
That is the cheapest solution and you have a LOT of flexility...
And if you find out what solution do you like, you can move foreward to Hypex nCore, MiniDSP - T-Amp or other.
Will yours be a desk setup or a living room setup ? Mine is planned for a living room. But no smart TV, only coax output so I am quiet picky... would love HDMI CEC... sooo comfy with chromecast on my Onkyo Reciever
which also works with bluetooth.
