Roland68
This thread is about DSP/crossover hardware with an integrated amplifier for 2-way (or 3-way) active speakers.A plate amp and a Wiim, that's all.
Plate amps do crossovers just fine. And fairly safe, reliable ones.This thread is about DSP/crossover hardware with an integrated amplifier for 2-way (or 3-way) active speakers.
My case is similar to OP’s, speakers will have uncommon shape, so installing a plate on the back is not an option. Also it would be great to reduce the amount of cables for aesthetic reasons, so all-in-one box would be a perfect solution.A plate amp and a Wiim, that's all.
You don't have to install it, just stick each one in a box nearby and you're golden.My case is similar to OP’s, speakers will have uncommon shape, so installing a plate on the back is not an option. Also it would be great to reduce the amount of cables for aesthetic reasons, so all-in-one box would be a perfect solution.
This sounds like a budget AVR.Bumping the thread because I’m looking for similar solution, maybe something new appeared on the market since last year. To be honest I’m quite surpsrised that no one produces affordable all-in-one box that would integrate DSP, 4 or 6 channel amps, AND a player/streamer. Everything in a single device that you can turn on with remote control or app and just play music from pendrive or Quobuz/Spotify. It would be like a holy grail for DIY speaker makers on a budget.
Only if the budget AVR can be configured for tweeter/mid/woofer crossover. I'm not aware of any that can.This sounds like a budget AVR.
What are the main differences between your devices and Dayton KABD/Wondom JAB5? I’ve read that KABD is a nice cheap starting point for beginners, but produces noticeable hiss. If it sounds like a noob question than yes, I’m a newbie.@Koifarm
I still owe you the 8 channel DSP board for tests.
Could not finish work on the software but now looks like it is converging, so please expect a parcel in 2 weeksI have the address.
Been busy with making the software to support different devices: DSP modules and new amplifier. Fixing many small things takes enormous amount of time.
Regarding the topic, in the recent months I was mostly working on this 4 channel amplifier:
It is designed as a plate amp, has USB audio + dsp config port, I2S and S/PDIF inputs.
For analog input there is also interface board with ADC. And for configuration it uses same software GUI as the 2x4 DSP.
I mostly post on DIYAudio about it:
Centure24: 4 channel DSP D-class amplifier
Made a first live demo video :) Sound level is a bit low, sorry about thatwww.diyaudio.com
I'll bring it here as well.
I think of two major differences:What are the main differences between your devices and Dayton KABD/Wondom JAB5? I’ve read that KABD is a nice cheap starting point for beginners, but produces noticeable hiss. If it sounds like a noob question than yes, I’m a newbie.
ADAU1701 has both ADC and DAC, so if you avoid using both built in ADC and DAC - yes, defenitely.So if someone uses only digital input in ADAU1701 is it possible to completely shut off ADC and eliminate hiss this way?
thomann t.racks DSP 4x4 Mini Review
Then this small market will be suddenly and extremely reduced again.
For such cases, I have an old used HP business notebook.
However, this is a test of the DSP without built-in power amplifier channels.Wow i completely missed this! Will study it tonight. Thanks so much!
Does the ADAU1701 have digital inputs and outputs?ADAU1701 has both ADC and DAC, so if you avoid using both built in ADC and DAC - yes, defenitely.
I am not so sure about DAC quality but the ADC is biggest contributor usually.
Yes, there are multifunction (MP) pins that can be configured for use as I2S input and output.Does the ADAU1701 have digital inputs and outputs?
