Pieter1267
- Joined
- Nov 20, 2024
- Messages
- 181
- Likes
- 100
Hi,
Looking for some user experience exchanges on the famous Quad 34 pre amp of the 80s.
The biggest draw for me was the tone control system. its actually called an ambler tone control read about it here
The bass control makes it very easy to increase bass at a set level for smallish speakers, or to take out bass, wich is ideal if you need to correct for instance, corner placement of your speaker and dont have/want to go through extensive PEQ control with REW and UMIK measurements.
The Tilt controle is for higher frequency adjustements. Normal and up dan down 2 settings. Its very simple, easy and in a way you only adjust something once or twice and then leave it there, whereas with other pre amps and equalisers, you are endlessly fiddling. This Quad system makes listening a very stress free exercise. Perfect for me.
This is comprehensive preview and test of the Quad 34
another website with Quad 34 info
Quad 34 service manual
One of the most important things to remind yourself as owner, is the radio input is fixed on 100mV while the Tape and CD is at 300mV. This gives a 10db difference in output on an already lowish 600mV main output. This Quad 34 was made to me connected to a Quad amplifier like the 405 or 606 but if you use a different amp, using the CD input especially will leave you wondering why it doesnt have the oomph you expected. Likewise, I feel that at higher volume settings, the radio inputs actually isnt the best. The volume knob is a rotary switch and gives different outputs at different settings. For instance, the steps between 1 and 5 is bigger than 8-12. Also, if you use the Radio input, you might feel difficult on lower volume settings to find a satisfying setting. If you play music through a DAC and put that in the Quad 34, usually the app (like Spotify) has its own volume slider. I find its better to make volune changes there, from the couch, and just put the Quad 34 volume knob at 5 or 6 (or higher if you want to enjoy higher SPL)
There are companies and also Quad itself might be able to adjust the output from 600mV to 1V (or maybe you can do it yourself).
Another quirk: the Radio input puts signal directly to the controls, while tape and CD has some kind of filter before sending it through.
