From infos I got online and measurements I made myself on my macbook Air m1:
Worst case scenario Sinad is 85+, most likely about 90db, best case scenario about 98db.
I'll explain: I was kinda limited by my ADC and the low output power of the MB Air M1 I could only hit less than 20 dbfs so the noise floor of the ADC limited the sinad at 85db. If I could have had more power or a quieter ADC it would have most likely been better. Even with lack of power noise floor is still below -120db and 2nd harmonic at -100db so everything below hearing threshold and we can't expect less from apple.
(Maybe I did something wrong I'm not used to do musellements..)
When looking at the specs of the cirrus logic chip it says: Worst case: 85db, typical: 90db THD+N, so it makes sense.
Best case scenario would be if noise floor really low which could be possible, it'd match the specs of the apple dongle.
For comparison Macbook Air m1 jack output is somewhat on par with JDS The Element but with less power.
STME and multi tone were ok in the same range of specs.
I measured Mac mini M1 and got similar results.
I've got the Macbook Pro too but I didn't bother measuring as I would be bottlenecked by my ADC. But a Chinese website measured it at 98db sinad, stme and multitone etc were ok too.
The hight impedance feature works fine. We should expect the specs to be about the same (98db sinad) but with more power I think the MB pro outputs 3 Vrms max above 150 ohm.
Apple cares about making quality products and I would be very surprised if they make a broken products with distortions or noise floor within the audible range. Their Dacs are good quality and transparent. But they also care about their profit margin and they'll most likely keep using the same Dac chips and circuitry that gets the job done for a small cost and it's highly unlikely they'll try to improve those numbers as there is no audible benefits for the masses.
Maybe I'll get a smsl SU1 for my mac mini (used as streamer) for the sake of it, but only once my room treatment is completed. If you have a mac, an external dac should come after room treatment, speakers, room correction/DSP and amplifier. If you got all those those sorted then maybe a Dac is worth it in my humble opinion.
