Any Known DIY kits or designs for stereo speakers that measure well on spinorama & play very loud?
But what wouldn't you do for bass?
I kinda liked the idea of a big folded bass horn, built in the basement and loading the mouth up thru the wall. ;)
Can't find the online photo any more ? :(
I’ve only seen one photo, and here it is::)
The bass system consists of two 6-meter-long bass horns. They are constructed from brick and concrete. The mouth of the horn emerges beneath the sofa. The horns feature hyperbolic expansion and extend down to 18 Hz; you can’t hear much down there, but it shakes both you and the windows.
The bass horns are equipped with a pair of 15-inch Klangfilm drivers.
You can read about the man who built the horn—speaker designer Bo Hansson—in post #625 of this thread:
A more practical approach, though, as I mentioned: "sacrifice" about 20 inches (50 cm) of the listening room and build a double wall. Install ten or fifteen bass drivers in that partition wall.
Fill the entire wall with them (perhaps a double wall 40 inches/100 cm deep). You might need two such walls to hit that 135 dB at 20 Hz.
Those walls can always be dismantled later if you want more floor space and are content with listening at volumes ranging from normal to damn loud.:);)
Is TS in some silly bass SPL competition, or what is this all about?
For some reason the photo doesn't look right with my memory but I believe that has to be it ?
Edit,
Nope, found it, this is the one I remembered. Now that's a friekin bass horn !
Edit,
There is more than one horn-nut in our world.;):)
Speaking of utilization, blending in, or functionality—here’s a clever horn design:
Okay, it won’t hit 135 dB at 20 Hz, but it almost certainly delivers more than enough bass punch.:)
This DIY builder uses this driver in that horn:
To revisit my rambling about partition walls: naturally, you could build a horn into one of those, too. An entire wall—like the horn above, but scaled up to cover the whole wall.
Ah YEA, If the math, etc; and all was done right, and looking at the build I have every reason to believe it was, that damn thing must sound incredible.
Bass of the GOD'S LOL
"SUBWOOFER horns are built underneath the floor in a cavity of 1 meter deep. Each horn is driven by 8 x 18" (47 cm) woofers. A total of 16 woofers.
Each horn is 9.5 meters long and has a floor mouth area of 2.2 square meters and reproduce starting from 10 Hertz FULL POWER. The real mouth area IS NOT the one on the floor. The real mouth have to be considered together with the side vertical frontal panels. The total horn is calculated onto the listening point considering the side walls and the ceiling loadings. This reduces the floor mouth that is not in open air."
Wow. Presumably you would be wise to reinforce your walls, to ensure the structural integrity of your abode when you have a house party? Lol
If you want to save some money look for a pair of JBL 5322 for top boxes and add a pair of dual 18" subs.
Like a youtuber testing a diy rotary sub at infrasonic frequencies?
Since we are at a stupid lvl, this will not reach the demands at 20hz but will above ~30hz
There should be more vids on the system but no in depth info or measurements
36 x JBL 2242 in a single bass array built i Norway
Or something like this, https://www.fidelity-online.de/wall-of-bass/
Well, I think the OP has figured out by now he needs a LOT of money. Also his parameters are really out of whack. The easiest thing to do is go with all Pro gear (saves a ton of money) and then tweak it from there. There is the hard way (DIY) or the easy way. I say go the easy way and just buy good pro gear. But, that is only my opinion and it will not even get you a cheap cup of coffee!
Are there any known diy kits or designs for stereo speaker systems (can, but do not have to, include one or more subs) that perform well on spinorama, handle full range 20hz to 20khz plus/minus very few db, can output continuously long term 120db spl over full range and 135db over lower bass range (not giving def for now of lower bass, can get detailed later if anything ballpark is available) due to human hearing fall-off there, and do all this with no audible distortion.
For home audio??? :oops:
I guess if your abode includes a grand ballroom or indoor basketball court. Perhaps
I think the funny part of the post is "can but doesn't have to include subs... 135dB bass" ... Sure I guess a 12 foot tall 4-way tower maybe technically doesn't have subs...
Let me guess. TS , @audioresearch wants high-quality hi-fi speaker capable of high SPL—that much is clear. Hi-fi, because the requirement—the wish—is that the speakers should: perform well on spinorama, handle full range 20hz to 20khz plus/minus very few db, ... and do all this with no audible distort.
That’s perfectly fine—who among us wouldn't want speakers like that? It would be a bit pointless to hang out on ASR if you didn't want speakers like that—or at least hold them up as an ideal.
So, it’s all perfectly reasonable so far, but then there’s this requirement from the TS:
...capable of continuous long-term output of 120 dB SPL across the full range and 135 dB in the lower bass range...
My guess is that these SPL figures were just plucked out of thin air, without considering what achieving them would actually entail in practice. It’s also a bit unclear whether the TS means 120 dB or 135 dB at 20 Hz, or 135 dB in the lower bass range (whatever the TS considers lower bass range to be).
Yep, agreed. No offense to the OP but I don't think he fully understands what a speaker package that could deliver on all those details would require in $, size, weight, etc. The extreme demands of the full FR combined with the SPL spec is somewhat possible, but at what cost and why?
I certainly don't mean to offend the OP; it’s only natural to have wishes and ideas. Later on, reality and practical considerations might reshape them, but hey—dream big... at least to start with.:)
I hope you don't think we're making fun of you, @audioresearch . That’s not the case at all; we’re mostly just considering whether what you have in mind is actually feasible—or how big and/or costly it would be.
Coincidentally, I suppose, there's also this poster harping on similar themes on ASR.
There's a universe of difference between 120dB and 135dB!
(8381A states 129dB peak, ok, not the biggest speaker out there,135dB is 1236A ballpark, but still... )
The other guy initially spoke of levels 'exceeding' 120 dB.
The conversation's mostly settled down to 'up to ' 120 dB.
