I think this is getting a bit into the Crab Bucket territory. Everybody has brand biases but it is not necessary to give misleading information about the brand one doesn't prefer. There are certainly issues with the launch of this product as I have described earlier. It is better to understand the issue exactly without misleading information to put a brand down. Then people can make informed decisions.
There will always be pros and cons between brands and devices. For example, the new Anthem line appears to provide a more sophisticated virtual input and profile selection for different settings than current competitors.
I would certainly not recommend it now with the launch issues and no official ARC Genesis but may turn out to be a nice options a few months down the road. There are not many options in this price range for a pre/pro. Perhaps the calculation for the full AVR might be different given the much larger choices there. I am only following the pre/pro owner experience with common functionality with the AVRs.
The above is not correct. There is no specific type of phone required. Just as, for example, Paradigm PW streamer WiFi can be configured via PlayFi app only, it appears the new AVM WiFi can only be configured by using the Google Home app (on Android or iOS phones or tablets). Nothing to do with any specific type of phone. One may indeed quibble about this method of configuring WiFi rather than directly via the device settings. This is a boot strapping problem with new systems that come with most settings now done with a Web UI which of course requires the device to be connected to the network first.
Just to clarify, this option seems to be available on the AVM Pre/Pros but not on the MRX AVRs. Whether the latter is a firmware setting issue or it simply not being available as a design decision ever remains to be seen. It may be a show stopper or not depending on one's use case and the need to listen to analog sources without using any crossover, DSP or Room EQ (which would require digitization on any AVR).
Did you read #352? Just for completeness...
https://www.avsforum.com/threads/official-anthem-avm-70-90-owners-thread.3181385/post-60471201
The problem seems to be in the use of ARC (beta version not officially available for the new line) at a sufficiently high volume setting. To me, it looks like some kind of digital clipping when ARC room eq is engaged and input is played at sufficiently high volume. This might be why the ARC Genesis is not yet available for the new line so it can be fixed to provide the proper attenuation before any boosts or to limit the volume when ARC is applied. But one would have to wait for the official release of the ARC Genesis software to see if this is a problem. Again, it points to a fumbled launch than any intrinsic problem with the device that will persist.
No need to make excuses for a fumbled launch just as there is no need to smear a device/brand without justification because of one's preferences for a brand. Let people make fully informed choices. People can certainly have preferences for themselves without being crabs.
This is why I recommend people reading the AVSForum ownership thread than rely on third-hand information here with selective quotes.
