Treblehead
- Joined
- May 22, 2024
- Messages
- 9
- Likes
- 3
I think the "comparison" is only about using two 2CH things, you still need to use the ARC setting to connect your 2 subs.I will use ARC Genesis to set it up. But after that, I read that ARC corrections can be turned on/off (if only for comparison). Will turning ARC off also nullify the sub setup and result in no subs?
However, you can try the professional mode to create a setting that only cuts off, for example, 80Hz of your main L/R speaker and provides the 20- 80Hz to your 2 subs without ARC correction.
How far is your listening position? Seems that you need a more powerful amp than the NAD M27.But I think my Sonus Faber speakers are a bit starved, sometimes I play at 90dB, and the space is huge. Living room is open to the kitchen and the second floor with 7m high ceilings, approximately 80 square meters.
