Mike-48
@Alexanderc
I just came across this thread and thought I'd respond, since I own an Anthem STR Preamp and a miniDSP SHD, and it doesn't look like you've chosen yet. My recommendation would the Anthem, either the STR preamp with an amp of your choice or the STR integrated (which I've not tried).
I have not used them in the same system or room and will not comment on perceived sound quality.
The main reasons for my recommendation are user interface and features. The Anthem feels like a unit designed by one firm from the bottom up. The SHD to me feels like a bunch of stuff pasted together. The interface is much clunkier and sometimes frustrating.
For example, upgrading software and firmware for the miniDSP is a pain. First, you have to download files from several place, then disconnect the SHD from your USB source, then connect a laptop to it with the USB cable. Then, with all those files, you search for the upgrade instructions, which miniDSP steadfastly refuses to include with the files.
To upgrade the Anthem, you download the ARC Genesis installer from Anthem and run it. If there is new firmware for the STR, it installs it automatically the next time you run ARC. If your computer and the STR both are connected to your network, the upgrade is made over the network. The same is true of making corrections with ARC. You don't have to hook anything more to the preamp itself; it's all done with your laptop and network connections. To make a correction on the miniDSP, you again have to disconnect the USB source, plug in your laptop, and proceed. Not impossible, but more of a nuisance, which in my case involves moving furniture.
When changing between correction profiles with the miniDSP, there is a gap of a few seconds. On the Anthem, it's much shorter, which makes comparisons easier. You can name profiles and inputs on the Anthem but not miniDSP.
The Anthem has DSP bass and treble controls. I love string quartets, and I can't tell you how many times I've dialed down the treble to accommodate poor recordings with performances I like. The SHD does not have those.
Finally, you are in Florida. The Anthem is made in, and is serviced in, North America. I don't believe there is a local service depot for miniDSP stuff; it has to be sent to Asia.
On the other side, Dirac is more flexible than ARC Genesis. I have gotten great results from Genesis, but if ultimate flexibility is your goal, you might prefer something that runs Dirac.
So for a more pleasant user experience, more everyday flexibility, and better serviceability, I recommend the Anthem STR line.
