I don’t think there is an AVR with balanced outs in the market.
Only prepros
Now THAT would be interesting!Now we just need an Arcam measured.
Yes but really because there's no reason to .So they could make more money.
You must also assume a zero cost or lesser cost for speaker output lugs which aren't needed. And you don't think you save on a much smaller power supply to a pre/pro vs power amps?
I don't know if the 60 is a 120 without amps or some completely different design. In this case, maybe a 60 without power amps and keep it single ended would be a good bargain.
Given Anthem's history, I would not expect a replacement before thenI also wonder about Anthems update cadence: These devices were released in 2017, I'm looking to build a HT next year. There should be a decent chance of a successor being released in the meantime, shouldn't there?
We could pick a few points from it and put it in the review tables.How arduous is it to compile that sort of graph
Thanks again for the loan. No, that alone would not do it but likely the ATI amp doesn't drop its power when more channels are driven like this one might.Would amplifier SINAD of 99dB compared to 86dB be considered audible, or am I just fooled?
Which arcam midel?
The THD specs for the 390 and 850 are the same (<0.02%), so they shouldn’t be too dissimilar.Which arcam midel?
