Anthem AVM90 AV Processor Review
Rate This AV Processor:
    Votes: 7 3.1%
    Votes: 15 6.7%
    Votes: 103 45.8%
    Votes: 100 44.4%
Yes Peng, I was thinking of using the 1140's amps only for the surround/height channels and the Buckeyes for the LCR.
One other thing that is bothering me now. I would like to use Qobuz to send hi-res audio to whichever pre-pro I get. I like the interface and the options. I do not really want to use Bluetooth, Wifi or string a cable from an iPad or whatever to the Pre-pro. But since I am understanding now that Anthem does not have the app natively on board, I would have to purchase another device (dedicated streamer) for more money AND in doing so, even if that device that I am spending more money on has a far superior Dac and Dac implementation, that would all be rendered useless since the Anthem would reconvert(?) using its own Dac because there is no option to directly passthrough??? I must be missing something.
The MRX does not have the adc/dac bypass option but the AVM has.
Why not consider the Marantz AV20 or AV30? They give you the paid option upgrade to DL, all the way to ART.
Curious Mark what your criteria was for selecting the Hypex NCx500 over maybe the Purifi 1ET6525SA were? Pricing is pretty close, so was it the extra watts? Other specs seem pretty close as well.
Best bang for the buck. FWIW I bought the 1140 for $3,199 shipped Dec. 2025. It was during Anthem's annual 20% off sales and I got a discount from the dealer for using a bank draft transaction vs a credit card.
Lot's of choices in Audiophile Land!
Pre-amp in the MRX1140 is better than the AVM's, it's cheaper and you get some amps to boot. https://www.audioholics.com/av-receiver-reviews/anthem-mrx-740-1140-receivers
Unsure why would make that comment, The AVM 90 has superior components, build & board quality, DAC's, power supply, you name it. There is a big difference in sound quality over the MRX and some definite improvement from the 70 to the 90, take it from someone that tested this unit extensively before buying it and put it up against the big box stuff that sucks sound wise (Denon, Martantz, etc). It's nearly comparable to the $14,000 Lyndorf and the MRX is not even close.
yawn......
This where we start to look at graphs but the reality of the sound actually coming out of these two different units is completely different. We can flash all the measurements but I ran the same amps, speakers, settings tuned and untuned and believe me the AVM 90 produces far better sound. Sound that I believe any ear can hear not just the trained ear. Not saying the MRX sounds bad it's just not at the level of the 90.
Just sent you a DM so as not to hijack this thread!
I'll just add that I have been very happy with my mrx 1140. It's a great option if you want an all in one setup for 2 subs and 7.2.4 configuration. I have had it for years in my HT room and it's been great for movies and music. The only real limitation I encountered is the onboard streaming options are limited to Spotify, Chromecast and airplay. These are generally fine for 2 channel music. I use a firetv cube and Amazon music for streaming dolby Atmos and high res music. So no real need to get an extra streamer or dac beyond using a streaming stick or Apple TV for Atmos music.
For what is supposed to be an Anthem AVM90 AV Processor Review thread, it seems odd some that have not owned or reviewed an AVM90, comment on other AVR’s. Seems a thread dedicated to those other products would be more appropriate or a new thread if they can’t help themselves and feel compelled to compare to something they have no first-hand experience with. One thing I have never experienced on social media is someone having their emotional opinion changed or being able to change someone else’s. I suppose it still makes them feel better somehow.
2-Channel is the priority in my family room and the AVM90 excels in 2-channel. If the AVM90 had a USB DAC input and an MC/MM phono stage like the STR, I would consider removing the STR from my system altogether. I do feel the STR has other advantages for 2-channel over the AVM90 but none I think I could differentiate in my room.
I recently added an Innuos Stream1 with LPS1 and the PhoenixUSB upgraded output board that is connected to the USB DAC input of the STR. I am able to connect one of the standard USB outputs on the Stream1 to a digital Coax input on the AVM90 by using a HiFace2 USB to S/PDIF Converter with RCA Output. With this converter, the AVM90 plays even the highest resolution files. In the attached picture, the AVM90 display shows a 192 file I was streaming from the Innuos. Innous suggested USB as the best connection but if I wasn’t using the STR, I could have configured the Stream1 with a digital output board that has a Coax output as well as a few other digital outputs.
With a number of decent amplifiers I have owned for years, including a Bryston 6BSST, 4BST and 7BST, preamps with balanced connections make sense if my setup, especially since the amps are in a different room and require long cable runs.
With a recent kitchen/family room remodel and my wife’s passionate hobby of décor, Anthem Room Correction is my option to tame my open concept space. It works very well on both the AVM90 and the STR. I have tested pure analog but prefer ARC and bass management in my open space.
After 448# posts, comments, it may come down to membership boredom.
Love your fur baby! :D
Just so I understand. You have an anthem STR and an external DAC, and 2 channel.music is the primary use, and you still have the AVM90 in the signal chain? For what reason?
Not sure where you see an external DAC. I don’t have one. I use the excellent DAC’s in the Anthem’s. The Innuos Stream1 does have an optional DAC board but I don't have it. I connect the PhoenixUSB output of the Stream1 and connect it to the USB DAC input of the Anthem STR preamp. They are completely different signal chains facilitated by HTB.
I also have a 5.2 AV system with a 77” OLED TV and the AVM90 shares amplifiers, FL/FR mains, and subwoofers with the STR while it is in Home Theater Bypass mode. For critical movie viewing, I use a dedicated home theater in my basement anchored by a JVC RS3100 but the Family Room setup is no slouch.
I’ve owned the STR for over 6 years and replaced a Denon AVR-X6500H with the AVM90 just over a year ago. The Denon is now used in a different room.
Family Room – 2.2 system: Anthem STR Preamp, Bryston 6BSST, 2 ea. Focal Diablo Utopia Colour EVO, 2 ea. Scan-Speak 32W/4878T Revelator 13" Subwoofer’s, SpeakerPower SP2-1400-HT, VPI Prime Signature 21 turntable, Ortofon MC Cadenza Bronze Cartridge, Innous Stream1 with PhoenixUSB, 4TB M.2 SSD and LPS1, Oppo BDP-103 for Redbook and 2-channel SACD.
5.2 system - STR HT Bypass: Anthem AVM 90, LG 77 CX, 3rd Focal Diablo Utopia Coulor EVO for CC, 2 ea. Infinity Cascade Model Nine surrounds, Apple 4K TV, Panasonic DP-UB820, Oppo BDP-103 for multichannel music, XG1v4. Bryston 4B ST, Crown XTi2 4002 Amp for in-house speaker system using zone 2.
I want to make a few comments on my Anthem AVM 90, it's not all paradise with this thing there is a tradeoff for great sound and it seems to come in the form of spikes and oddities with the flexible full featured Anthem ARC software, yet is has issues. The output on the ARC to the speakers is so hi and sometimes even inconsistent causing potential damage to your pricey speakers, that's no small issue. I hoped that Anthem would have a solution for this but to my knowledge they do not have a solution. Any comments are welcomed. However, I don't see any way around this problem, you can turn down the ARC volume but it will randomly spike up on it's own adjusting it back to high if you go to low on the volume. How it decides you are too low is a DB level unknown to me. Do I have to ask if any other AVM90 owner is having this problem because I'm sure you are.
ARC is not the problem. ARC does not damage speakers. Owners do. Recommend you get some help here after you've figured out. https://www.avsforum.com/threads/de...68892/page-645?post_id=64880263#post-64880263
One of the reasons i reconsidered getting an avm70/90 was because of that. Others have mentioned it and one youtuber had his centre speaker damaged. They call it the banshee wail. Think its the processor not arc though.
It has been mentioned that another forum has a long AVM 70/90 thread. In that thread a very small, possibly no more than a single handful of owners, have mentioned the Banshee wail and/or a sudden increase of volume. As far as I can tell, it is unclear if the two issues are related nor what has caused them in the few instances reported.
I own an AVM 90 and have never experienced any problems. I use Apple TV 4K and anecdotal evidence mentioned a Roku in the chain of those that reported problems. I have done limited research to validate this.
You mention ARC software as the cause. Are you referring to Anthem Room Correction? I ask because many suggest you turn off all HDMI controls including; ARC, or Audio Return Channel, eARC, or enhanced Audio Return Channel, and CEC, or Consumer Electronics Control. The two ARC acronym represent completely different features. Again, I have done limited research to validate this but I always turn any and all of these options off. They tend to cause issues or at least make it more difficult to troubleshoot what are already complex enough AV configurations. I do use Anthem Room Correction (ARC) with great results and with no issues.
ARC, or Audio Return Channel, lets your TV send audio to an external audio device such as a Roku Streambar, Roku Streambar Pro, or Roku Smart Soundbar without the need for additional cables.
eARC, or enhanced Audio Return Channel, is the next version of ARC and supports high-bitrate audio formats. Not all devices that support ARC also support eARC and eARC is not backwards compatible with ARC.
CEC, or Consumer Electronics Control, allows commands to be shared between devices over the same HDMI connection as audio and video, letting you control common functions of different devices without having to juggle remotes.
Here is the formal response from Anthem on this topic. I will try it tonight to see if those random spikes continue and post my results here, I typically set it lower but I will set it right in the recommended range.
From Anthem Directly:
Hello Hal,
Prior to running ARC genesis you must use the Quick Measure function to set reference level. Within the ARC software open quick measure and set the output to your sub 1. Begin quick measure and target a sub level of 75db (-3db for each additional sub in the room) using the subs gain level. Once you have your subs set you can proceed with running the full room correction software.
Regards
Hello Hal,
Regards
Hope that works. I watched a couple recommended setup videos before running ARC and that step was a pain since I use passive subwoofers and the sub amplifier is in another room in the basement below. I needed to keep going down to adjust the level and back up to run quick measure again until I reached the suggested target at which point I could run ARC. I also needed to make the db adjustment since I run two subwoofers. Good luck.
Yeah, I just picked up two new SVS SB-5000 Evolutions so I really need those to work well given the investment. :)
I asked another question on tweaking the DB levels here is Anthem's official feedback for those experiencing the issues. This is definaty an issue as there is no clear way to ensure it doesn't spike your speakers as I have already in fact tweaked my MIC settings to various levels in an attempt to try and avoid this issue:
Verify Your Windows/Mac Microphone Input Level
Anthem's response:
A common situation occurs when your computer drastically drops your USB microphone's software input level down to 20% or lower.
    • When ARC perceives that the background audio or incoming signal is extremely quiet due to a low mic setting, it commands the receiver to push the speaker output louder to get a clear reading.
    • Open your computer's system sound settings while ARC is running and ensure the Anthem USB microphone input slider is at an appropriate level (around 50% to 100%) so the software can easily hear the room without ramping up the receiver's physical output.
