I used RCAs for a few months before switching to XLR, never had hum/buzz issues with RCA. Imo, you should try to find the root causes first and solve it, balanced output don’t really eliminate the causes it just cancelled it though not always completely. As to SINAD, going to XLR you may lose a couple dB but may be not, assuming you could fix the hum/buzz issue. I expect the units that use the ES038Q2M will do better on the bench but I would not expect audible differences.Just curious:
Is there a comparison/measurements of AVM 70 SINAD of RCA vs XLR? I know AVM 90 performs better on RCA out...
The unit tested by Amir in this thread seems to be the early with AKM DACs. Later Anthem switched to ESS - is there a measurable change in SINAD, or about the same? Has anyone measured?
Trying to understand how much I will lose, if I switch to XLR cables to resolve the humm/buzz. I purposefully purchased RCA cables in the hopes to be better, did not expect humm/buzz from speakers...
