Audiophilehi
What would be the serial numbers to identify late 2023 and beyond?
Some in the AVM 70 owners' thread on the AVS forum have said that the noisy fan issues they experienced were apparently caused by the fan profile programmed into the firmware installed in their units, because it disappeared after a firmware update. Others maintain that it's a random hardware issue, unrelated to firmware or build date, and that replacement of the fan on the CPU is the only remedy, short of returning the unit.
I won't speculate either way. Mine has been installed on a shelf in one of my 19-inch equipment racks, with about 2 inches of clearance above it, and I imagine it becomes warm, despite the back of the rack being open. Yet, I have never been able to hear its fan at all, even with my ear only an inch or two away from the unit's faceplate. I can certainly hear the 80mm variable-speed fan in the Crown CTs-4200 when its on and driving my height speakers, but not the fan in this. I purchased the unit in November, 2023, and it's a pain in the nether region to pull out the rack far enough to retrieve the AVM's S/N. I will if you really believe the issue is related to the build date, but I sincerely doubt that it is.
How exciting.Just to update this thread, I decided to purchase the Anthem Avm 70 8k processor. The cost was within my budget and preference's.
Now the short wait. It should be delivered in 2 days.
Great choice! The official Anthem manual includes quite a bit of irrelevant MRX information that may inadvertently make setup more complicated than need be, but I can send you a copy of the AVM-specific documentation that I pieced together from the manual and Anthem's website if you message me your email address. Also, I'd be happy to help with any specific questions that may arise during installation and setup.Just to update this thread, I decided to purchase the Anthem Avm 70 8k processor. The cost was within my budget and preference's.
Hi Anton,Great choice! The official Anthem manual includes quite a bit of irrelevant MRX information that may inadvertently make setup more complicated than need be, but I can send you a copy of the AVM-specific documentation that I pieced together from the manual and Anthem's website if you message me your email address. Also, I'd be happy to help with any specific questions that may arise during installation and setup.
The document should be in your email inbox.Hi Anton,
That's very generous of you and very much appreciated. I always like to do the same myself.
Message sent!
Got it!! Thanks again!!!The document should be in your email inbox.
wOOt, A new AVR. I''m sure after you get it all dialed in you'll be thrilled with the new immersive audio codings. Let us knowJust to update this thread, I decided to purchase the Anthem Avm 70 8k processor. The cost was within my budget and preference's.
No. The USB input is for software updates only.Can you use the usb input on the Anthem AVM 70 for usb audio? I would like to connect my Aurender N100H.
Not sure that is correct: you should be able to do thisNo. The USB input is for software updates only.
Yes it is correct the manual mentions nothing about USB being available as an audio input.Not sure that is correct: you should be able to do this
But do not hot connect USB to Aurender: could cause damage
Thanks but what do you mean by “Hot connect USB to Aurender”? What I would like to do is connect my Aurender USB output to the Anthem USB input.Not sure that is correct: you should be able to do this
You cannot do that the Anthem USB port is for *service* only it does not support a USB audio device like the Aurender.Thanks but what do you mean by “Hot connect USB to Aurender”? What I would like to do is connect my Aurender USB output to the Anthem USB input.
I am sure others know more about this than I do but…I did this between an Aurender USB out to a Benchmark DAC and caused damage to both units.
Aurender explained that while hot disconnect of USB is normally OK, it is not with their USB port for HD audio: and there was a warning in the instructions to turn the units off first.
Aurender repaired the unit at no charge: the Benchmark unit was new so I returned it
Just my experience
