Anthem AVM70 Review (AV Processor)
Hi all. Quick question...
I have an AVM70, still in its box. The plan is to run 9.2.4 for now.
I have a pair of side surrounds that can run either Bipole or Dual-monopole (PSB Imagine Surround S)
For another coupla hundred dollars, I'm thinking of buying another 2 channels of amplification, going dual-monopole and letting DSU or DTS upscale / matrix to achieve 4 channels on each side, rather than 2. What do we think of this?
Sounds like something I would contemplate and in the end be extra overkill. So you’re trying to achieve 11.2.4 but it’s going to come from the same source point and I’m no expert but I don’t think that will make a difference and I’m not even sure what content would even provide that for you.
As I said, not an expert but I don’t know if anyone would mix a movie to have a 2 channel output audio in two different directions.
Next I think the other factor someone who is knowledgeable in the matter would want to know is where do you plan on putting this in your chain ie rear surround, side, or wide. However in all those situations that’s where I’m unable to see why the sound would be split in the fashion you are imaging by doing this
Don't take this the wrong way, but that speaker is an older design that offered now outdated "hacks" for greater flexibility with older non-discrete content. I would just run it in straight bipole mode as a single channel for each speaker.
Well I was quoting someone who said not having Auro-3D was a dealbreaker - that's dismissing Anthem Logic out of hand.
There has always been Cinema and Music settings, and IIRC only the Music setting ignored centre channel, and got a lot of praise for doing so and avoiding the widespread criticism of up-mixers that the centre image collapses into the centre
No Auro 3D ?? That's a deal breaker for me...
I mostly prefer Auro-3D in Denon when listening to music as I find the stereo mode is not up to what I need. And here I am talking about the X*800 series.
I think with Anthem the music setting sounds much better. You can't even tell if the center channel is ignored, but I could easily tell in Denon.
Maybe it is my calibration, but the Anthem seems to sound better in music out of the box and here I am not referring to the 70/90 series.
No, the AVM70 does not have the ES9038Q2M. At launch time, according to the marketing information, it was the AK4490 but after the factory fire, they apparently had to switch to a different one. There does not seem to be any confirmed information on which IC they switched to.
I seem to remember reading it from somewhere that they went with the ES9010K2M but I could be wrong, my distant memory is not reliable. Sadly and sort of expectedly, when they switch to something better they will tell and brag about it, but if they switch to something not as good, then they tend not to talk about it.
Yes you are correct they did use the AKM dac u til the fire then switched to the ES9038Q2M. It’s the unit that I bought.
I said that 2 years ago, we have since known that they switched to the ES9038Q2M.
Can one stream directly from Qobuz, TuneIn, etc., to this?
As far as I know, the only supported streaming service for direct streaming with the AVM70 is Spotify. I've tried Qobuz, that didn't work.
I have the MRX1140. It supports Spotify, Airplay, and Google Cast. That's it. I wouldn't hold my breath for any other direct services showing up as Roon "coming soon" has been for many years now.
Is it true that the AVM 70 has no manual parametric EQ?
Correct. The bass and treble controls are only available when “Convert Analog 192kHz” is selected or when any digital input is used. I think it’s pretty cool that the AVM70/90 allow you to bypass any digital conversion. I’m not sure if this is the same as the “Pure Direct” mode found on most other processors/receivers, where the bass and treble are also bypassed. It’s a great feature, especially if you’re using a turntable and want to play a true AAA record.
For the price (vs Trinnov, Storm, Lyngdorf), is there really any better processor solution than the Anthem 70/90 if one prioritizes high fidelity/transparency (aka, measures well)?
Seems at least as of today it is the best (only) choice. There is also Denon, Marantz, Emotiva, etc, which aren’t terrible (but far from great), but I fear for the future of these brands. Anthem seems quite solid in that aspect.
I would love to have the Lyngdorf MP-40, but too rich for my blood, unless I could find a used unit.
Actually the Marantz AV10 did measure better, just a little.
For those willing to use avrs as avp, the 3 Denon top and one Marantz model are much cheaper amd likely measure about the same, though that’s somewhat speculative.
The Anthem is one of the best choice imo if one wants to listen to music with no dsp/rc/eq, otherwise I would pay more for the AV10 and DLBC licence.
Reactions: MKR
After using several AVRs over the past 10 years (Onkyo, Yamaha), I have to say I prefer the AVM across the board—whether it’s for music, movies, the interface, tech features, or room calibration. This is my first experience with a separate processor and amp setup, and I honestly don’t think I’ll ever go back to an AVR. That’s my perspective. That said, Yamaha, Onkyo, and Marantz are also making some really impressive high-end units.
Reactions: MKR
Of course, everyone chooses theirs based on their own reasons. Is yours the 90?
I also considered various solutions before I decided on the Anthem AVM70, mostly based on the review here at ASR. I wanted a dedicated pre/processor with balanced outputs, superb measured performance at a reasonable price tag. Other possible choices (including NAD M17) were way too expensive for me, with little or no gain in fidelity in my opinion.
I've actually done a proper level matched listening comparison of the AVM70 and a MiniDSP Flex, which performs better (higher SINAD). I was comparing 2-channel DAC performance only, and could not distinguish between the two. That tells me that the performance of the AVM70 is as good as it gets.
And I didn't find the AVM90 sounded any better or even different, then I re-visited the ASR reviews and saw no reason for the 90 to sound different than if two subs are used and the compared conditions are the same. The 90's SINAD and IMD (obviously) was a few dB better, but at almost 100 dB the 70 is in the transparent to humans territory.
So, as much as I was very tempted to pull the trigger on the AVSF members raved (yes including my electronics friend Theo:)), I decided to save my $4,000 (or was it more..). To me, the AVM70, now that it is finally virtually bug free is a tough AVP to beat. Objectively ARC G sucks compared to D+M's (with apps), but it is good enough for all intents and purposes subjectively, I just have to forget about curves and use my ears and imagination only. If I were to do it again, and did not have the external amps already though, I would definitely have gone with the Denon AVR-X3800H, or the X6800H if on a good sale. That's based on my very good experience with the X4400H, and obviously, the price, money saved would then go for the DLBC license plus 2 extra subs, that's where the audible sonic gain would come from anyway, at least in theory.
Reactions: MKR
Thanks all for the great feedback, certainly seems the AVM70 (or 90) is truly the “audiophile’s” pre/pro. The Marantz AV10 also looks very interesting, but given the recent ownership changes of Marantz, very concerned about future support.
I also did consider the Denon AVRs, but with active speakers for the front/center, would be paying for amplification I would never use. Not to mention the Denon has same long-term support concern as Marantz.
So, I am quite certain I will go with the 70 or 90. Actually likely will be the 90. I realize the audio performance gain between 70 and 90 is inaudible, but plan for this pre/pro to be in my system for many years, so may as well splurge a bit for the best of the best. Also this pre/pro will replace my current dedicated 2ch DAC/preamp signal chain, so it has to provide the utmost in transparency. The AVM90 looks to provide a bit of “holy grail” capability … superb audiophile (2ch) and cinema (MCH) performance all in one box!
But a bit of a wrench in the spokes … I can obtain a Lyngdorf MP40 for a very attractive price (albeit still more expensive than the AVM90). While the the MP40 does not appear to be quite as transparent as the 90, as with 70 vs 90, close enough I suspect as to be inaudible to my ears. What really sets the Lyngdorf apart is the Room Perfect room EQ which based upon what I have read here on ASR and other forums is as good as it gets, even vs the famous Trinnov and Storm units.
Thoughts and opinions on 90 vs the MP40?
Thanks all!
Thanks all!
The 90 is not more transparent than the AV10. The AV10 beats it in pretty much all metrics if you compared the test results here on ASR. The so called upgraded audio is based on marketing info that does not tell us what those so called/claimed better parts are. It is the same thing when Marantz claimed that have a mire musical and/or warm sound. It is all about a strategy, to create some reasons that would enhance the well understood Placebo effects or expectation bias among their fan base.
Marantz at least tell us about their volume ICs and OPA ICs, not just the DAC ICs. Anthem did ustilized a slighly better DAC but the ESS reference class dac in the AV10 is already at the extremely "transparent " level, a whopping 120 dB SINAD, vs Anthem's better IC spec'ed at 122 dB. Yet the AV10 measured a touch better, some would attribute that to implementation, that often may matter as much as or more so than the better IC can do.
As to the MP40, I have not seen comparable measurements, and not sure if Roomperfect would do better than ARCG, Audyssey and Dirac. It is not hard to do better than ARCG though, for use who don't want to spend time on post calibration manual tweaks.
On the objective side, DLBC and Audyssey with the app(s) are really good based on many actual measurements posted on forums, such as those measured with REW. For pure direct mode use, the AVM90 and the AV10 are practically equals. The AVM70 and 90 are more transparent for analog input sources, at least based on specs.
In terms of differences in transparancy between those gear, it is probably academic, because even -85 dB THD should be perceived transparent for humans, especially for those older than 40 who likely cannot hear much above 15 kHz. For those who could hear, may not perceived it as more transparent either.
EDIT: Keep in mind Anthem has been offering about 20% discount a few times a year, at USD 6,000, it becomes a lot more attractive.
