It’s most likely sighted bias, but I wonder if there are bigger differences at lower output voltages.
Anthem has 29 dB gain for their amps.
50 milliwatts of power is what you might be using for a quieter scene. With a 92 dB/W speaker, 15 feet listening distance, 50 mW is 65 dB, which is like running -20 on a setup calibrated to be 85 dB at +0 which seems pretty reasonable to me.
4 ohm speaker would mean around 0.45V at the amp.
So then you subtract 29 dB and now you are at 16 millivolt output at the preamp stage where SINAD is going to be way lower.
If I use the dynamic range measurement then residual noise is 0.025 mV. (4V - 104.5 dB).
0.025 mV is 56 dB below 16 mV.
Since I said we are listening at 65 dB, I assume there is 9 dB of noise. If you had 11 channels, 9 dB x 11 adds up to 20 dB, which is rustling leaves?
The math is probably off a bit since some 29 dB nominal gain amps only do 23 dB for XLR, but people have complained of hiss with the AVM60 (which was 10 dB worse of dynamic range). My math is also with high efficiency speakers and 15 ft listening distance.
@amirm, have I done the math correctly? The
German Stereo magazine has always done 50mW and 5W measurements for their amps.
I know there are an infinite number of tests to add which eats up time, but is there value in adding 50 mW testing to your amps and maybe doing a SINAD sweep from 50-200 mV for AV processors to capture realistic loads at 29 dB gain?
It might allow better understanding of real world scenarios (unless the math from your 4V testing and dynamic range calculation is good enough and running the test just duplicates what we can approximate well with math).
Given that you have 5W for amps, maybe it makes sense to test AV products at
4V = compare standalone DAC against processor
150 mV = what you need to reach ~5 watts with a 29 dB gain amp or ~50 mW with a low gain amp?
(Rounding for convenience)
That will provide some value to both AHB2/LA90 users and Marantz AMP10 “in bridged mode” and be like running the dashboard and maybe a multitone at the 150 mV output level?
