I am looking to replace my Anthem AVM 50V Preamp/Processor which is currently paired with an Anthem PVA 7, Magnepan MG1.6/QRs, MGCC2s, and an MGMC1, a SVS SB-3000 sub, and a JVC DLA RS-1100. My inputs are an Apple TV 4K, a Denon HEOS Link HS2, and a PS5. I want 4k @ 120fps and equivalent or better SINAD than the excellent Burr Brown OPA-2134 implementation in my AVM 50v. I bi-amp the MG1.6/QRs and do not need/want more than my existing 5.1 channels given my room specifics and difficulty integrating additional channels with my beloved Maggies.
The Anthem AVM 70 is beyond my budget, so I am considering a ToneWinner AT-500 or AT-600, Denon AVR-X3800H or AVR-X4700HBKE3, Marantz Cinema-70S, or the Yamaha RX-A4A since they have full preamp outputs so I can still use my Anthem PVA 7.
There is very little good information about the performance and quality of the ToneWinner products, but they look intriguing. I understand the feature differences between the Denons and would appreciate feedback on the sonic and build quality differences between them since they are different product generations. Finally, I know that Marantz is made by the same company and that the Cinema-70S has received negative reviews, but I do not know whether the issue is with the av processing which I care about or the power amplifier stage which I will not use.
Thank you in advance for your input.
